Throttle body (NW 92) doesn't fit LSXRT 102mm Manifold
Old Jul 21, 2013 | 11:04 AM
RezinTexas's Avatar
Thumbs down Throttle body (NW 92) doesn't fit LSXRT 102mm Manifold
Doing my LSXRT swap this weekend and all was going well. I got the manifold bolted down 100% flush with the heads all around. I can't imagine any vacuum leaks there, but we'll see.
My tuner (Patrick G) recommended the NW 92mm TB from Scoggin Dickey. I found it on WS6 store for about $40 less, so I got it from there instead.
So I go to bolt on the TB and this is the result. Picture shows underside of TB
This is obviously not acceptable and will very likely cause a bad leak.
Has anyone else seen this before? Are all NW 92 TB's created equal?
Scratching my head with this one...
Old Jul 22, 2013 | 11:04 PM
zero2sixT's Avatar
weird. the car style is supposed to be able to run the stock 90mm tb. The truck should be able to also. But maybe you could make a thin spacer to make it work. Did you call comp yet? Or maybe where you bought the tb?
Whats the lsa on the cam youre running?
Old Jul 22, 2013 | 11:21 PM
Atomic's Avatar
I have a gauge for that
My nw 92mm did the same thing on the stock intake, worked fine.
Old Jul 23, 2013 | 06:00 PM
RezinTexas's Avatar
I sent the TB back to WS6 store and Mike is going to send me a FAST 92 in exchange (plus the price difference).
which stock intake? this intake is 102mm, so I don't see how there could be the same issue with a stock intake.
Old Jul 23, 2013 | 06:09 PM
RezinTexas's Avatar
here is the cam card. the cam was spec'd by Patrick G, with the LSXRT intake as part of the input.
Old Jul 24, 2013 | 07:33 PM
zero2sixT's Avatar
I'd like to see how it runs. Seems like most people who have had problems are running a tight lsa.
Old Jul 24, 2013 | 09:59 PM
Atomic's Avatar
Stock L92 intake.
You can just barely see it in this pic:
Old Jul 25, 2013 | 04:53 AM
RezinTexas's Avatar
^ interesting. are you talking about the small gap on the right side?
Old Jul 25, 2013 | 04:54 AM
RezinTexas's Avatar
I'll keep you posted. New TB should be in tomorrow, will try to schedule a re-tune ASAP.
Old Jul 25, 2013 | 09:40 AM
Atomic's Avatar
No im talking about the gasket showing on the bottom (green) that you were worried about.
