Throttle body help.
Old Apr 12, 2010 | 07:57 AM
Svt KlR's Avatar
Default Throttle body help.
Hey guys hows it going. i have run into a problem with my motor swap that i am doing, i am swapping in a 6.0l out of a cadilac and put a edlebrock pro flow xt manifold on it after being told that the stock tb would fit i found out that it most definently will not. now getting a ls2 90mm tb isnt a big deal but the wireing harness conectors are differnt the 90mm is a 6pin and the stock 6.0l is a 8pin.( its a drive by wire )
So if there is anyone that has used this manifold on a 2003ish silverado that used to have a 5.3l if you could tell me what you used for a tb that would be extremly helpful thx.
Old Apr 12, 2010 | 11:56 AM
lsxmalibu's Avatar
you can use the stock TB ( 3 bolt) on the newer 4 bolt with an adapter plate.
Old Apr 12, 2010 | 06:24 PM
DrX's Avatar
DrX
Lots of us are running LS2/LS7 TBs on 2003 - 2006 trucks. Google "LS2 throttle truck"
Old Apr 13, 2010 | 08:12 PM
Svt KlR's Avatar
Thx for the info guys, does anyone happent o know about how much hp gain i will get if i go to the 90mm over the stock 78mm i am going to school and kinda on a budget right now and i dont want to have to spend 700 bones tuneing it then they say that it isnt getting enuff air and have to spend that much money again.
Old Apr 13, 2010 | 11:29 PM
DrX's Avatar
DrX
I would stick with whatever TB came from the factory on the motor if the motor has not been modified and needs more air. In stock form I don't think you will see much gain from the larger TB.
Old Apr 14, 2010 | 10:27 PM
Svt KlR's Avatar
It is nto stock nemore it used to be a 5.3 i swapped in a 6.0l 30 over bore heads cam new intake nitrous new lifter rockers and everything.
lucas287
31
Jan 12, 2021 06:18 AM
blownss27
Aug 14, 2020 08:27 AM
murderedSS
27
Oct 12, 2015 11:13 AM
99bluefirebird
Sep 17, 2015 08:05 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
