Throttle body choice with TBSS intake
Old Oct 21, 2012 | 11:23 AM
porksoda's Avatar
Default Throttle body choice with TBSS intake
Getting ready to finally throw on my TBSS intake manifold. I already have an 87mm TBSS throttle body but would i gain more by porting it or going to a 90mm car throttle body? I've been trying to read but I get confused when everyone starts talking about gold blade vs silver, ls2, ls7. So basically I wanna know what is the best choice for a bolt on and cammed silverado ss. I've seen ls2 ones on ebay for 150ish but can port and poliah this 87mm for cheaper obviously.
porksoda's Avatar
And before anyone asks yes I do know I will need an x link.
Old Oct 21, 2012 | 11:44 AM
TXSZ66AVLANCHE's Avatar
What engine? Larger throttle body usually will hurt your lower power band, for a 5.3 87mm is fine.
Old Oct 21, 2012 | 11:48 AM
porksoda's Avatar
It's an lq9. Just don't know if there is a known better throttle body everyone uses on these engines.
Old Oct 21, 2012 | 11:53 AM
andrew383's Avatar
traveling mod
I plan on running the ls3 tb.. Alot of guys here just run the 87mm tb tho..
Old Oct 21, 2012 | 10:25 PM
zachm89's Avatar
I just installed my TBSS manifold today and used the Ls3 gold blade 90mm. I believe only the 2.1 and newer xlink work with the ls3 tb but don't quote me, that's just what I've heard. I would assume that there would be somewhat of a difference between the truck and car tb's but it is probably so minimal you'd never notice it.
Old Nov 4, 2017 | 08:17 PM
johnboy92's Avatar
Under Boost
Default Ls3 throttle body
hey did you have any fitment issues with the throttle body? I have a lq9 06 sssand I'm doing the tbss intake swap but I have a ls3 90 90mm gold blade that I'm trying to install hut the water pump to radiator hose barely clears and that's with me smacking on it lol thanks
Old Nov 4, 2017 | 08:27 PM
johnboy92's Avatar
Under Boost
did you ever get the 90mm?
Old Nov 5, 2017 | 12:42 PM
turboal1's Avatar
Default 90mm T/B
I have the LS3 T/B from a Camaro on my
truck manif, 2011 6.2 fit no prob, works great.
Old Nov 9, 2017 | 11:10 PM
johnboy92's Avatar
Under Boost
yea but yours is the 6.2 which in assuming has a different style water pump lol I have an 06 sss and it's a different style where the neck of the water pump comes so close to the 90mm tb. Thanks for the input tho man
