Throttle Body Bypass Kit
Old Feb 3, 2006 | 11:29 AM
GatorFan's Avatar
Default Throttle Body Bypass Kit
I'm doing some research and was wondering if any of you have ever used (or are using) a Throttle Body Bypass Kit. I found one for around $17.00 and was considering buying it. Any comments? Any noticable gains (at all)? The company boasts a 6 HP gain but I'm still skeptical.
I plan to install it on my 4.8L
Thanks,
GatorFan
Old Feb 3, 2006 | 11:35 AM
SS_bnoon_SS's Avatar
Thanks,
GatorFan
17 bucks?!?!?! If indeed you do need hardware for this, you can buy the hose cheaper at a hardware store. On my 2003 SS, I didn't even need to buy any hose to bypass the TB, the stock hose was long enough to reroute it. Took 20 minutes tops and was free...
Old Feb 3, 2006 | 11:46 AM
white1's Avatar
Reroute for free, I bought the kit it went to the round file. And 6hp. I think they left the decimal point out .6 maybe. I did it, and would do it again for free, but I didnt notice anything.
Old Feb 3, 2006 | 11:50 AM
ZR1 DREAMING's Avatar
you guys wouldn't happen to have any pics would you? where exactly is the coolant re-routed to?
Old Feb 3, 2006 | 11:59 AM
Mangled03gmc's Avatar
Baltimore Whore
I just used a small peice of stainless pipe I had lying arounnd in the garage and 2 vacume block of ends and 2 wire ties. It worked great. ZO6 instead of the fluid runing threw the tb you just use the pipe to connect the 2 hoses togather....
Old Feb 3, 2006 | 12:39 PM
SSlow 4.8's Avatar
on the bottom of the throttle body is an inlet and outlet which a small hose flows coolant through. Looking at the throttle body you take the right most tube (inlet) and connect it direct to the outlet (so completly bypassing that hose from the tb). All you need really is some extra hosing and two ends that come with that kit your talking about.
It honestly doesnt help much, but it will keep the throttle body a bit cooler.
ill try and get some good pics for you if you need it.
Old Feb 3, 2006 | 01:50 PM
thunder550's Avatar
High on diesel fumes
Yeah, if you can do it for free or maybe a dollar or two go for it, don't waste your money on a kit. It's worth almost nothing performance wise, but hey, can't complain much if its free or $1 or $2.
Old Feb 3, 2006 | 02:17 PM
TXsilverado's Avatar
5/16 brass barb will do the trick. 3$. theres plenty hose there to just unhook em and connect em. do it with the engine cool!(learned that the hard way)
Old Feb 3, 2006 | 02:23 PM
$thatguy$'s Avatar
it's alot easier to do if you take the intake tube off to... just go to the hardware store and tell them you need a hose coupling 1/4 or 5/16 will work and there sould already be some hose clamps on the hose.
Old Feb 3, 2006 | 02:44 PM
Post
Either way guys, unless you did a before and after dyno run with or without the bypass, you will not feel 5-6 flywheel HP gains.
I doubt it even gives you a gain, but who knows.
Jim
