Throttle Bodies
Old Aug 24, 2006 | 01:10 PM
Default Throttle Bodies
which is the better of the 2 a nick williams 90mm or a fast 90mm throttle body please help me so i can get this stuff on the way.
Old Aug 24, 2006 | 01:15 PM
ZR1 DREAMING's Avatar
Most guys on Tech like the NW of the two. Reason being when FAST came out with the 90mm TB at first it had a defect causing the butterfly to hang at WOT. The NW peice was desinged to eliminate that problem. Supposedly all the new FAST TBs are re-designed and do not have that issue anymore.
Old Aug 24, 2006 | 01:16 PM
which would you buy if you were fixing to order one with the fast intake
Old Aug 24, 2006 | 01:33 PM
The Nick Williams...
Old Aug 24, 2006 | 03:34 PM
BlackGMC's Avatar
Resident Retard
Kinda off the topic, but how are the BBK 80mm TB's. I saw some in the summit catalog the other day.
Old Aug 24, 2006 | 03:55 PM
I had FAST throttlebody that had the sticking problems and switched to a UMIracing throttlebody,it has an eliptical opening that offers vastly improved low speed throttle response.UMI is the best way to go if you plan to drive around on the street.
Old Aug 24, 2006 | 04:35 PM
zippy's Avatar
I also like the UMI and Nick Williams. I haven't seen you around in a while. How's the 408 coming?
Old Aug 24, 2006 | 04:42 PM
If you really want to be adventurous I have a 90mm FAST that I will sell for $50+plus shipping.
Old Aug 24, 2006 | 05:20 PM
PM sent!
Old Aug 24, 2006 | 09:49 PM
samdogmx's Avatar
8 Second Club
NW all the way
