Threw away $100 today.
Old Oct 22, 2010 | 03:40 PM
  #21
suddenurge's Avatar
I cut 14" off my tailpipe, and that reduced my drone by at least 50%. I did it to my OEM exhaust with an 18" Magnaflow swap and with my current JBA catback. Both times it worked wonders.
Old Oct 23, 2010 | 08:10 AM
  #22
Allgonoshow's Avatar
you could test the pipe lenght theory by temporairliy removing the tail pipe.
any other thing to consider is the hangers, if you have custom pipes and the steel hangers are loose in the rubber mounts on the frame, this can set off a vibration.
Make sure all the hangers are tight in the rubbers,
althought I don't have a blower our exhaust is similar, mine does not drone
Old Oct 26, 2010 | 07:02 AM
  #23
KA41's Avatar
So do you think I will have any problems going with a single 3" from the 3.5" cutout back to the rear behind the tire, not only from a sound perspective but performance as well.
Old Oct 28, 2010 | 06:05 AM
  #24
Just put the largest 3.5 resonator that will fit in front of the muffler.
you could put 3 inch on it to change the sound and you wouldn't loose much if any performance, might even gain some low rpm power.
Old Oct 28, 2010 | 11:08 AM
  #25
ShredSled's Avatar
Yeah, I think the bullets are more to cure rasp than drone, like mentioned earlier in the thread. I put an SLP LM2 in front of my Corsa to get rid of the horrible rasp after my cats were ditched, and it worked perfectly. I have mine dumped before axle and it doesn't drone at all... But on the other hand, I put a magnaflow on my Jeep XJ and it drones worse than any flowmaster I've heard, and that's with the cat still on there.
Which reminds me, anyone here ever hear of having a length of tube (not really sure how to determine length) welded into the exhaust system perpendicular to the direction of flow, but blocked off on the end? I forgot what this method is called off-hand, but this supposedly cures all drone, might help you out, esp. if you want to kill it completley, not just move the frequency up the rpm range.
Old Oct 28, 2010 | 11:21 AM
  #26
TX Tahoe Z71's Avatar
Yep, heard that works the best. Here's a good read: https://www.performancetrucks.net/fo...d.php?t=424169
Old Oct 28, 2010 | 12:59 PM
  #27
ShredSled's Avatar
oh yeah, that's exactly what I was trying to say in my horrible attempt to explain! Thanks for the link.
Like one guy there mentions, possibly similar to the factory intakes too...
bearden86
25
Nov 1, 2015 07:12 PM
dewmanshu
Oct 5, 2015 06:21 PM
Velocity1
Oct 2, 2015 08:01 AM
Slammed silverado
Sep 28, 2015 06:14 PM
