Thoughts on this E-fan switch?
Old Apr 27, 2005 | 12:16 PM
TigerFan187's Avatar
Default Thoughts on this E-fan switch?
I will be putting th LS1 fans on soon and was going to get a Nelson harness but I also wanted the ability to overide the PCM and manually turn them on say if Im at the track. I assume that some of you have that setup. Im trying to figure out if this is the same as the Nelson harness plus the ability to override the pcm or what.
http://www.stealthperf.com/cgi-bin/store/63011.html
How have most of you with the Nelson harness set yours up?
Old Apr 27, 2005 | 12:23 PM
LARRY01Z28's Avatar
the nelson harness is awesome. and the best thing is just tell him and he will add you a switch in for free. and you can flip your fans on whenever you want to. thats what i have.
Old Apr 27, 2005 | 12:28 PM
OK! Is there a extra connection for that or is it already wired in the harness?
Old Apr 27, 2005 | 12:32 PM
greentahoe's Avatar
It is just a switch wired to a wire tap and ground that you connect to the pcm pin wire. It works perfectly.
Old Apr 27, 2005 | 12:50 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
what he said
Old Apr 27, 2005 | 01:12 PM
Thank you boys!
Old Apr 27, 2005 | 08:14 PM
Dark Halo's Avatar
how much does the nelson harness run?
Old Apr 27, 2005 | 08:45 PM
budhayes3's Avatar
PT's Slowest Truck
$89 plus shipping ($10 shipping here to New Jersey)
Texas5.3_1251
Mar 5, 2016 08:10 PM
lxcoupe
Sep 11, 2015 03:17 PM
iregret
Sep 7, 2015 01:20 PM
God Made Chevy
Sep 4, 2015 12:29 AM
jtphelps289
Sep 1, 2015 08:58 PM
