Thoughts on a cam
Old Aug 28, 2016 | 10:32 AM
xerox17's Avatar
Default Thoughts on a cam
Currently I have a '03 ecsb 4.8, 1 3/4 long tubes, 3" ory, cut out, cai, Tuned by cal speed(they're local), and 4.10's with a g80 in the rear. The truck runs pretty well for having 150k miles stock trans and stock motor with 22 inch wheels and 265/35-r22 tires. I am wanting to do a decent size cam and a circle d 3200 stall to really wake it up since i cant afford a turbo kit right now and 6.0's are over priced to say the least here. The cam I had been looking at that seemed like it would be a great fit based on specs after doing research on the different parameters and what they affect is the Comp cams SUMLSGT100 (https://www.summitracing.com/parts/c...t100/overview/).
Does anyone have any experience with this cam or know anyone that does? What is everyones thoughts on it for a DD street truck with a 4.8? Any clue what kind of numbers i would make with the listed mods and the cam stacked on top of it?
Thanks for any advice in advance.
Old Aug 30, 2016 | 01:52 PM
Whitecrewcab's Avatar
I had one very similar in a 5.3, it was 218/224@.050 .564/.581 lift on a 110 LSA, sounded awesome, but was a bit flat below 3500. From there to 6400 though, it screamed. In a 4.8, I would probably look at at least a 3600 stall and maybe 4.30-4.56 gears. That cam will probably peak at 65-6600, so rod bolts become a good idea.
Old Aug 30, 2016 | 01:54 PM
Here is what mine sounded like at idle, a 4.8 will be even choppier.
Old Aug 30, 2016 | 11:09 PM
xerox17's Avatar
what else was done to it? Was that thru cats?
Originally Posted by Whitecrewcab
06 Silverado with a custom cam - YouTube
Old Aug 31, 2016 | 12:30 AM
1 3/4"x3" long tubes, 3" off-road y, single in dual out muffler, TBSS intake, 90mm throttle body, CAI, springs, pushrods, 3000 stall and 4.10's. It made 330rwhp on the Power Tour dyno.
Old Aug 31, 2016 | 12:32 AM
I eventually had to put the cats back on it to pass inspection where we went TDY, but I don't have a clip of it with them back in.
Old Aug 31, 2016 | 09:31 AM
Slow05CC's Avatar
Avery@texas-speed.com
TSP 220r .600/.600 on a 112 with a 3000-3200 gets my vote.
Old Aug 31, 2016 | 01:39 PM
Aaron at SDPC's Avatar
Former Vendor
The 216/222 camshaft would work decent in you application with the planned torque converter swap. I definitely wouldn't recommend anything larger for your 4.8.
Old Sep 6, 2016 | 07:10 PM
xerox17's Avatar
Whats the reasoning behind this statement?
Old Sep 6, 2016 | 07:11 PM
xerox17's Avatar
Would you just not recommend anything larger for a daily driver due to idle issues?
