those of you who have swapped cams/springs...
Old May 20, 2009 | 12:21 PM
Noah Burns's Avatar
Default those of you who have swapped cams/springs...
did you actually check install height for the new springs and make necessary adjustments, or did you just pull and replace? just curious how many people here actually do/did it right.
Old May 20, 2009 | 12:25 PM
BlackGMC's Avatar
Resident Retard
i just pulled and replaced with the LS6 springs... The PRC duals that i have now came with the heads...
Old May 20, 2009 | 12:27 PM
Noah Burns's Avatar
did you have the heads on it when you brought it to the dyno day over in Saginaw?
Old May 20, 2009 | 12:29 PM
BlackGMC's Avatar
Resident Retard
nope stock heads and a 222/224 cam..
Old May 20, 2009 | 12:30 PM
BigMikeGXP's Avatar
just pulled and replaced, didn't even know there was anything to adjust.
Old May 20, 2009 | 01:57 PM
Noah Burns's Avatar
Michael, the adjustment is in the height of the spring versus the "install" height of the valve... sometimes shimming may be needed to make the heights meet.
Old May 20, 2009 | 02:32 PM
00ChevyScott's Avatar
Wearin' da big hat
Just pulled and replaced
Old May 20, 2009 | 02:54 PM
LaSinister's Avatar
pulled and replaced
Old May 20, 2009 | 03:14 PM
dug's Avatar
dug
Banned
same here, when I installed the cam in my old camaro, I just took out the old springs and put in the 918 springs. No problems for 25k miles then I sold it.
Old May 20, 2009 | 03:24 PM
1989k1500's Avatar
pulled and replaced every time.
