Those of you with the LS1 intake swap
Old Oct 26, 2006 | 02:28 PM
99/5.3w/hips's Avatar
Default Those of you with the LS1 intake swap
Of the few folks that have done car intake swaps with the LS1 intake instead of the LS6 which parts were you able to re-use from your truck intake and what did you do about the accessories? did you go car or keep the truck water pump and accessories?
Old Oct 26, 2006 | 02:40 PM
BLACK04VHO's Avatar
ok I have seen a tone of write ups and in person results on the ls1 car intake swap. I can tell you right now your not going to get any performance out of it. Our truck intakes flow very well until you get over 6000rpm and then they can still do a decent job. I just wouldn't waste the time on doing it unless your just looking for a cleaned up engine compartment. IMO but it is your truck just thought I would throw that out their.
Old Oct 26, 2006 | 05:09 PM
my intake seems to be running out of breath above 5600 rpms
Old Oct 26, 2006 | 05:33 PM
truck intakes flat line peak usually around 5600 or 350 n/a rwhp
Old Oct 26, 2006 | 05:45 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Dont you have a stock cam?
Old Oct 27, 2006 | 09:43 AM
no i have a 02 z06 cam but I will be going with a TSP 220/220 on a 112 soon
Old Oct 27, 2006 | 09:45 AM
1slow01Z71's Avatar
I would do the intake I posted about as an alternative to the LS6, it flows better and if you know the right people you can get it cheaper then the link I posted.
Old Oct 27, 2006 | 09:55 AM
I dont have to do the 4 barrel tb do I? Cause that could get expensive.
edit: nevermind I was thinkin about your vic jr and 4 barrel set up you were talking about. in your other thread. Yeah I will check this one out.
Old Oct 27, 2006 | 10:03 AM
1slow01Z71's Avatar
https://www.performancetrucks.net/fo...d.php?t=377641
Old Oct 27, 2006 | 10:20 AM
yeah i just looked at it. the satin one is only around $420.00
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
HectorM52
Aug 18, 2015 12:40 PM
Ketis
Jul 23, 2015 12:37 PM
Black-Syde
Jul 6, 2015 02:12 PM
