Those running LS1-style injectors in here...
Old Mar 14, 2008 | 02:48 PM
  #21
03sierraslt's Avatar
Originally Posted by BlownChevy
The best 15.00 you will spend:
MSD-2400 @ summit racing dot com
Thats what I did..
Old Mar 14, 2008 | 03:01 PM
  #22
thunder550's Avatar
High on diesel fumes
I just cut mine and used some butt splice connectors to put the new pigtails on....no problems here. No soldering either.
Old Mar 14, 2008 | 06:37 PM
  #23
OnyxSilveradoSS's Avatar
with the L76 intake you will need different orings to use your car type injectors. I am still working out what else on the truck intake, I think it will just be o rings on the 42 marine injectors for plug and play in my application but I have not checked to see how the fuel rail will sit.
Old Mar 14, 2008 | 07:00 PM
  #24
06sierra5.3's Avatar
im hoping i can take the end caps off my truck injectors and use the different o-rings, then just plug-and-play
what i was wondering is the setup from scoggin dickey comes with the rails and injectors all complete. do the car connectors plug into these new injectors?
Old Mar 14, 2008 | 09:53 PM
  #25
BigKID's Avatar
I went to the local Pick-N-Pull, found a V8 Aurora and got the entire injector harness for $5. All the wire colors matched up with my harness. I soldered and heat shrinked all the connections. It looks pretty close to factory and haven't had any problems.
A few pics: (they were a little big and I didn't feel like resizing so just click the links to view)
Connectors
Cut-up Harness
Finished Product
Old Mar 15, 2008 | 04:14 PM
  #26
Whippled 496's Avatar
Originally Posted by kbracing96
Whipple496 has come up with the parts to make adapters for plug and play truck harnesses to LS1 style injectors. I got a set should be here tomorrow so I will be able to see how they work on my truck. (going with some 60's) He's fixin to put them on his truck this weekend. Might look into this if you really don't want to cut the stock harness.
Installed the 60's today along with the adapters....everything worked out very nicely.
Old Mar 15, 2008 | 04:35 PM
  #27
So is she running?
Old Mar 15, 2008 | 06:24 PM
  #28
do you have a pic of the conversion harness whippled496?? and could you PM me the cost, thx
Old Mar 15, 2008 | 10:38 PM
  #29
https://www.performancetrucks.net/fo...d.php?t=412938
PM me if your interested.
Old Mar 15, 2008 | 10:43 PM
  #30
bluecajun5.3's Avatar
11 Second Truck Club
Originally Posted by Whippled 496
nicely done sir!
