Those running LS1-style injectors in here...
Old Mar 14, 2008 | 11:51 AM
ZR1 DREAMING's Avatar
I did not solder mine, I actually cut the wires at the ends and crimped on the new wire ends and installed them in the new plugs. So I have no cuts or anything, it looks factory.
That's kind of what I was thinking about doing as well.
Old Mar 14, 2008 | 11:56 AM
03sierraslt's Avatar
You need a specific crimper to do it, I forget what its called. I had one, but I do allot of electrical wiring so.... Damn, Ill find out the specific name of it for you.
Old Mar 14, 2008 | 11:58 AM
Great, thanks!
Do you have any pics by chance also?
Old Mar 14, 2008 | 12:10 PM
06sierra5.3's Avatar
what about the pins? are they different. what about releasing the pins from the connector and putting the new connector on the factory pins. if the pins are the same then you can swap connectors back and forth without cutting anything.
otherwise i am gonna try and make my truck connectoors work with the l76 manifod. cutting my harness will be a last ditch effort
Old Mar 14, 2008 | 12:11 PM
No the pins are different. Hold on ill dig up some pics.
Old Mar 14, 2008 | 12:15 PM
Here is a picture of the stock injector pins.
And here is a pic of the EV1 pins.
Old Mar 14, 2008 | 12:59 PM
BlownChevy's Avatar
blownerator
25 Year Member
The best 15.00 you will spend:
MSD-2400 @ summit racing dot com
Old Mar 14, 2008 | 01:25 PM
SS_bnoon_SS's Avatar
Whoops, nevermind. I didn't see page 2 with the part number.
Thanks for the part number blownchevy. Added to Summit wish list...
Old Mar 14, 2008 | 02:02 PM
1TRUESS's Avatar
This is what I did too!!
Old Mar 14, 2008 | 02:12 PM
what about the l76 manifold setup frm scoggin dickey do thse injectors mate with the same style car connectors
has anyone been able to make their truck injectors fit with the l76 manifod yet? i know it can be done with the ls6
