Thorley vs OBX
Old Oct 22, 2008 | 12:11 PM
  #61
Moddoo's Avatar
Originally Posted by 02SilveradoLT
Moddoo, you got the black ps. Or when you got them coated you got the black coating?
I got the black ceramic from Jethot.
Your truck is stock. Get a good tune. Headers suck without a tune anyway.
Then get a cam when you are ready.
If you still want headers after that, save enough to get something that you will be satisfied with.
My $.02
Old Oct 23, 2008 | 04:07 PM
  #62
02SilveradoLT's Avatar
Originally Posted by GMCtrk
You can't have everything for cheap. You either compromise and get the OBX's for $500 or pay $1000+ for dynatechs, american racing, etc.
My truck is 4wd, and I dont feel right putting a huge dent in my new headers. That is why im ruling out the thought of using OBX......
Old Oct 23, 2008 | 04:12 PM
  #63
My $.02
When I do decide to get my headers I will be getting a tune at that time also. I do have another thread started comparing higher ratio rockers vs a mild cam. What are your thoughts on the higher ratio rockers? As it would be much easier to install these vs a cam. I know in terms of power a cam would dominate the rockers. But if and when I do get a cam I would go mild anywase.
Old Oct 23, 2008 | 05:27 PM
  #64
GMCtrk's Avatar
I don't recall truckmann putting any dents in his headers. You should PM him and ask him yourself.
Old Oct 23, 2008 | 05:58 PM
  #65
Leroy_454's Avatar
Are the thorleys stainless? What makes them any better as far a winters as the pacesetters? I would see what material they are made of.
Old Oct 24, 2008 | 08:44 AM
  #66
Gordy M's Avatar
The Thorleys come chrome plated or coated. I had the plated ones for four years in Michigan where we generously use salt in the winter. While the headers turned blueish, there was almost no signs of rust.
Old Oct 24, 2008 | 09:33 AM
  #67
sharpshooter's Avatar
How do Thorleys compare with most standard longtubes when it comes to performance?
Old Oct 24, 2008 | 04:23 PM
  #68
Gordy M's Avatar
Thorley's are considered a mid length header so they are better at low end torque and give up some HP above 6000 rpm
Old Oct 25, 2008 | 09:29 AM
  #69
brent1976's Avatar
11 Second Club
I have the OBX headers on my 4x4 with no problems. I've had my y pipe out 4 times, and each time I put it back together the header was touching something. All you have to do is loosen the header bolts, and the band clamps adjust them where you want them, and tighten the band clamps, then the header bolts. You can make the sit anywhere you want like that. I've got 1/4" to the frame on the passenger side, and 1/2" to the stearing shaft, and 3/8" to the front ds. I didn't think it was that big of a deal.
AHelm3
Apr 8, 2016 07:51 AM
Angry Silverado
Oct 21, 2015 07:07 PM
1989k1500
Sep 29, 2015 10:53 AM
styleandspeed
Dec 20, 2004 07:34 PM
1999stepside
Jul 1, 2003 09:21 PM
