Thinking of L92 heads for my lq4. Thoughts??
Thinking of going to l92 heads on my lq4.
My lq4 currently has stock 317 heads, 226/230 @600. 112+4 with a tbss intake and 90mm tb.
Thinking of going to L92 heads and l92 truck intake and milling the heads .030.
What u guys think??
What u guys think??
You will also want a new cam that will favor the exhaust a little more with the L92's.
IMO if you are doing a head swap, and changing all that other stuff, you might as well stick with the cathedral heads and get something that will outperform the L92's.
Seems like a lot of hassle for not a ton of gain for that swap IMO.
Mike
Milling them .040 will put you at a 64cc chamber. I had a cam that I was told was a bad cam 244/248 .612/.615 112+2 for l92 heads and I went 10.64 in an extended cab truck in my old 10.6:1 compression motor. New motor is 11.8:1 compression and has a cam for these heads. 251/267 .623/.623 115+6 and I only gained 20hp..
So saying you have to have cam for these heads to work is irrelevant IMO.
I wouldn't hesitate to swap to these heads.
glad this thread came up, I have a brand new rec port TBSS intake kicking around and just bought a LQ4
was debating on either putting my 799s on or getting a set of L92s
hope this thread makes up my mind
Your going to spend over twice as much on a ported set of heads than going with l92 heads to make the same power..
On my old 370 I picked up 45 hp going from 243 heads milled .030 to l92 heads with a cam that's supposively not for l92 heads.
Mike
