Thinking of L92 heads for my lq4. Thoughts??
Old Aug 2, 2013 | 12:44 PM
WhiteChevy3's Avatar
Default Thinking of L92 heads for my lq4. Thoughts??
Thinking of going to l92 heads on my lq4.
My lq4 currently has stock 317 heads, 226/230 @600. 112+4 with a tbss intake and 90mm tb.
Thinking of going to L92 heads and l92 truck intake and milling the heads .030.
What u guys think??
Old Aug 2, 2013 | 01:23 PM
Vortec350ss's Avatar
You will also want a new cam that will favor the exhaust a little more with the L92's.
IMO if you are doing a head swap, and changing all that other stuff, you might as well stick with the cathedral heads and get something that will outperform the L92's.
Seems like a lot of hassle for not a ton of gain for that swap IMO.
Old Aug 2, 2013 | 02:32 PM
Mikey 97Z M6's Avatar
11 Second Club
What u guys think??
Have you calc'd out the compression ratio with those dished LQ4 pistons? Seems like even if you milled the heads .030 the compression wouldn't be that great. I milled some L92's .030 and paired them up with some flat top pistons and got 11.3:1 so with a dished piston I think you'd be lucky to get 10:1.
Mike
Old Aug 2, 2013 | 07:19 PM
Blackpanther99's Avatar
If your going boost YES the L92s are worth it, otherwise dont even bother getting them. Stay with 317s.
Old Aug 2, 2013 | 07:48 PM
dirt track racer 81's Avatar
Milling them .040 will put you at a 64cc chamber. I had a cam that I was told was a bad cam 244/248 .612/.615 112+2 for l92 heads and I went 10.64 in an extended cab truck in my old 10.6:1 compression motor. New motor is 11.8:1 compression and has a cam for these heads. 251/267 .623/.623 115+6 and I only gained 20hp..
So saying you have to have cam for these heads to work is irrelevant IMO.
I wouldn't hesitate to swap to these heads.
Old Aug 2, 2013 | 08:14 PM
WICKEDOWESIX's Avatar
IMO L92 heads in a 4" bore shroud the valves ( hence why they are in a 4.065" bore). Stick to some ported cathedral heads.
Old Aug 3, 2013 | 12:01 AM
GREENSIERRA's Avatar
glad this thread came up, I have a brand new rec port TBSS intake kicking around and just bought a LQ4
was debating on either putting my 799s on or getting a set of L92s
hope this thread makes up my mind
Old Aug 3, 2013 | 09:52 AM
Your going to spend over twice as much on a ported set of heads than going with l92 heads to make the same power..
On my old 370 I picked up 45 hp going from 243 heads milled .030 to l92 heads with a cam that's supposively not for l92 heads.
Old Aug 4, 2013 | 10:13 AM
hog's Avatar
hog
The L92 heads do come in 4" bore application stock. LY6 etc.
peace
Hog
Old Aug 4, 2013 | 10:37 AM
11 Second Club
If your intake has rectangular ports then you must have a L92 truck intake, not a TBSS intake. To my knowledge TBSS's never came with rectangular port heads, only cathedral style.
Mike
