Thinking about swapping heads
Old Jun 3, 2018 | 07:35 AM
madmann26's Avatar
Default Thinking about swapping heads
I’ve been toying with this idea for sometime.
The current heads are TMS CNC 317s at 69cc. I believe the intake is 235cc.
I procured a set of 243s. I want to have them gone through and milled down to 59-60cc, which bumps my compression up quite a bit.
Here’s the hard question, is it going to run better or worse?
Anyone have any thoughts?
Old Jun 5, 2018 | 05:35 PM
madmann26's Avatar
So, I'm moving forward with this.
I am going to mill the 243s .025, run a .051 gasket.
I should be around 11.5-11.8cr.
Thoughts?
Old Jun 5, 2018 | 07:33 PM
10 Second Club
Doubt it will hurt it. Just don't expect huge gains.
Old Jun 5, 2018 | 08:28 PM
1FastBrick's Avatar
Custm2500's Rude Friend
With no port work? Don't be surprised if you lose some power on the top end.
Old Jun 6, 2018 | 04:44 AM
madmann26's Avatar
That's what I'm afraid of.
On top, it pulls like a damn freight train. 3rd gear, from 80'ish to redline (6500) it holds a rock steady 12.5-12.7 afr.
Would it be better to to swap head gaskets?
Even with a calculator, going from a .051 HG to .027 (Cometic) only bumps up the compression to around 11.5.
I also understand that this will tighten the quench up and my DCR goes from approx 9.1 to 9.7.
Old Jun 6, 2018 | 12:20 PM
gagliano7's Avatar
With the higher compression it should feel way better at low rpms and still perform at high rpms.
Old Jun 6, 2018 | 12:33 PM
Vortec350ss's Avatar
Your quench will probably be too tight with a gasket that small.
climb-101
Aug 16, 2016 10:26 AM
Gadgetized
Jun 23, 2013 10:09 AM
mred
Jul 30, 2010 07:34 PM
SuperchargedSS
Jul 25, 2009 08:41 PM
Silvy6.0
16
Jan 31, 2009 09:43 PM
