Thinking about putting a TR220 in the 6.0
Old Jul 7, 2009 | 12:54 PM
chevyguy7802's Avatar
Default Thinking about putting a TR220 in the 6.0
How do you guys think the tr220 would perform in the 6.0? When I took
the stock 6.0 out to the track it ran a 8.7 (1/8) in the heat. The only mods are ls6 intake,cai,lt's,3k stall,and 4:10s. I really want to stay with a smallish
cam with this motor, let me know what you guys think!
Old Jul 7, 2009 | 03:08 PM
joeyc125's Avatar
11 Second Truck Club
its great in my truck, power pulls to around 6200, and in od and tc locked at 1700 rpm i can give it a little gas without unlocking the tc and gain speed pretty easily.
Old Jul 7, 2009 | 04:40 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
id say either a TR-220 or a TR-224 would be a good cam with the stall your running what happen to your old iron LS1?
Old Jul 7, 2009 | 05:59 PM
Yea im just wantin to try out a small cam. I just took it apart a couple weeks ago and it turned out to be a spun rod bearing, itll be a quick fix I just think im gonna use it for another project.
Old Jul 7, 2009 | 09:16 PM
fastrt's Avatar
I will give you my low mile tr224/112 if you get me a good used tsp 224r/112. pm me
Old Jul 8, 2009 | 06:11 AM
Tootall's Avatar
I ran a 222/224 566 568 -112 for a while in a stock headed 6.0 with no stall and I loved it
Old Jul 8, 2009 | 11:54 AM
I'll think about it! How are you likin the tr224 in your 5.3?
Yea ive thought about that cam too, how much rpm would it pull with your
setup?
Old Jul 8, 2009 | 12:25 PM
00ChevyScott's Avatar
Wearin' da big hat
David (dlt76028) is running a TSP 224 XE, and has had GREAT results.
Old Jul 8, 2009 | 01:00 PM
Tootall's Avatar
setup?
shift points were 6300 and 6000 . . . pulled all the way
It was more for bottom end torque. I could stomp just about anything from a dead stop to 3rd gear
again, there are better ones out there. I've done several swaps with the low and high lift 212/218. Its an all around cam
Old Jul 8, 2009 | 01:56 PM
LsxCody's Avatar
I would think a 220 cam would make good power in you're motor
