Thinking about larger cam, pros/cons?
Wearin' da big hat
As of right now I have a 216/220 .525 .532 114Lsa comp cam and have pretty good results with it at the track. It sounds pretty good and pulls good in my truck. But after I put in my stall, it seems to have ate up alot of my top end pull and is leading me to think that I need a larger cam.
So I am thinking about trying the Patriot Performance 226/226 .585 .585 112+2
(https://www.patriot-performance.com/...&cat=49&page=1)
The only thing I am worried about is the lift on this cam. I am running stock 862 heads, and will most likely be keeping them stock for awhile. Will having this high of lift on stock heads actually hurt my performance?
Also, will I gain a noticeable amount of power switching to this bigger cam? Would it be worth it?
Wearin' da big hat
cam,4.10s,full bolt ons, built tranny, 4k stall
It's my DD so I don't know if i want to go too much bigger than that cam unless it's not going to hurt my MPG that much more than it already is.
he's already got a 216/220....im not sure going to a 224 even warrants a cam swap. Dozer dan is running a 232/237 or someting like that in his 5.3. He'd probably be the best one to ask about which cam to go with.
it may be a 216/220 but the lift isnt very high at all. talk to corey (blackgmc) he just went larger in his 4.8. if im not mistaken its bigger than the cam you have now in your 5.3.
