Thinking about going true dual
Old Jul 22, 2008 | 08:57 AM
00ChevyScott's Avatar
Wearin' da big hat
Originally Posted by PathfinderJr
right, but even 2.5" duals are decently big for only 325 cubes. 2.25" duals is just a tad larger x-sectional area compared to a 3" single. It just doesn't sound as manly to say 2.25" duals I guess...
Just for a comparison, even though its different generations of small-block, the hopped up 350 in my '66 truck made ~400hp/~415lb-ft torque on an engine dyno. Torque was about 400 lb-ft at 3.5k all the way until about 5k. This was running through 1-5/8" headers with 2.5" collectors, and has 2.5" duals on the truck with an x-pipe.
I could be wrong, but I doubt the engine in your truck is that strong, and you'd have more area under the torque curve in the usable rpm range that you'd be in on a day to day basis with 2.25" dual. But hey, its your truck, so do whatever pulls your trigger.
I'd say I'm in the 380-390 hp range at the crank man. And i see plenty of guys running true dual on completely stock trucks around here with no problems. but I'm still thinking about going with zzebes exhaust.
Old Jul 22, 2008 | 09:08 AM
bluecajun5.3's Avatar
11 Second Truck Club
alright, don't listen to us then.
let your performance suck with 3" into 2.5" true duals
what zzebes has?
Old Jul 22, 2008 | 10:28 AM
InchUp's Avatar
Originally Posted by 00ChevyScott
I said I wanted to do dual 3" into the X pipe, then dual 2.5 out...
It's still a power sacrifice across your entire rev range except for maybe 6500 rpms. If that's where you think the motor will be revving all the time then sure, dual 3" it is.
If you think you're in the 380-390hp range, dual 2.5" is all your motor requires. I'd go as far as necking down to 2.25" after the X-pipe to keep exhaust gas velocity up.
Old Jul 22, 2008 | 02:03 PM
ChevyTruck's Avatar
something else
i have 2.5" all the way to the mufflers then 3" from there on out. noticed a difference from silngle 3 from high flow cats on out, to the dual exaust.
Old Jul 22, 2008 | 02:37 PM
Wearin' da big hat
what zzebes has?
no, his exhaust is 3" single.
Old Aug 21, 2008 | 10:42 PM
supercharged tahoe ss's Avatar
old set up stock y pipe magnoflow 1 into 2.5 inch dual 451 torque new set up pacesetters high flow IMCO metal core cats x pipe 2 16 inch imco mufflers 3 inch from front to back new set up 492 torque. engine is out right now getting all forged new dyno numbers comming soon. [IMG]
Raggedz71
Jul 29, 2016 10:20 AM
thewrx
Aug 12, 2015 08:28 PM
Zack R
Aug 3, 2015 06:02 PM
lxcoupe
Jul 30, 2015 02:42 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
