Thinking about finally doing a cam.
I only have 12k miles on the truck. I am not doing a stall for awhile. So, is there a good cam out there that makes good power and doesnt need a stall to retain driveability? FI is out of my price range right now. My plans are for now just going with a cam, tune, and headers. Also, if I went from 3.73's to 4.10's would that help with not having a bigger stall?
I was thinking of this Vinci cam
"043" 210/218 .531/.531 114
I did my cam about month ago, I think it was the best mod yet. Marc W is using that same cam in his SS and he loves it. He also has not done a stall either. He said he doesn't see the need for one, he also has headers and is a 6 liter though.
I have a 206/212 cam from Cam Motion that I really like. No aftermarket stall required. Gained about 15-20 RWHP across the band, but the biggest gain was off the line, which was a pleasant surprise. I recently went from 3.73's to 4.10's and wish that I hadn't. Very little gain, and quite a few trade-offs including worse mileage (from 19 mpg to 17), shorter gear range (shifts sooner), and higher RPM's on the freeway, which contributes to greater noise at lower speed. I'll probably be going back to the 3.73's.
Banned
You Can Also Look @ The 01 Zo6 Cam Works Real Good In Trucks And On Dyno Pull All The Way Up 2 6700 If You Want The Cam Is Small And Is Gm.you Can Get The Zo6 Srping Also The Cam Is About 250.00 And The Springs Are About 130.oo. Just Check It Out Before Buying One
