Think it's getting time to change my brake pads--which ones?
Old Oct 20, 2004 | 10:53 AM
14 Second Truck Club
Default Think it's getting time to change my brake pads--which ones?
It's getting harder to stop my truck, think it's time to change out the brake pads. Which ones are ya'll using with the stock 16" Aluminum rims?
Thanks.
Old Oct 20, 2004 | 01:40 PM
Tires are more important then brakes. They have a more dramatic effect on braking performance.
But if you insist, I just put on some hawk pads. They are a little more pricey then OE pads, but for my purposes, suburban, towing, etc it fit the bill nicely. Aprox $70
Raybestos pads are fine too at $30 or so it's a bargain.
Old Oct 20, 2004 | 01:59 PM
Ryan23silverado's Avatar
Use the GM OEM pads
Old Oct 20, 2004 | 02:41 PM
Richard, go with the gm durastop ceramic pads. The temp range is higher, reducing brake fade, & the brake dust is a light grey, no discoloration.
Old Oct 20, 2004 | 10:14 PM
Hey Blake, how much are they? I'll probably get some in a month or so, it's not to a critical point yet. I can just tell that they're getting a little weak.
Thanks for the responses guys!
Old Oct 20, 2004 | 10:27 PM
storm5.3's Avatar
13 Second Truck Club
How many miles you got on that '99 ??? Mine still have a lot of meat left at 159,xxx miles. I was getting worried too so I checked mine a few weeks ago and still have around 3/8" or so left, course I do alot of hiway driving if that matters. Just wondering...Zed
Old Oct 20, 2004 | 11:51 PM
You might also check out the Wagner Thermoquiet brake pads. Gauranteed not to squeal, low dust formula and they last along time.
Old Oct 21, 2004 | 12:23 AM
It's got about 64,500 miles on it so far. 80% of my driving is stop and go around town.
Old Oct 21, 2004 | 12:24 AM
I'll look into it, thanks.
Old Oct 21, 2004 | 12:48 AM
from what i have been told it is best to run the OEM pads unles you completely redo the brake system, cause which would you rather have go bad, the pad or the rotor....im no pro but thats what i have been told....correct me if i wrong...
