Is there a big thread that swaps a 6.0 into a 5.3?
Old Dec 26, 2009 | 02:30 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by viciousknid
arent those the ones with longer cranks? My memory fails me a lot.
Yes, that is correct.. 99-later 00 had them..
Old Dec 26, 2009 | 02:40 PM
dirt track racer 81's Avatar
Sucks gettin old dont it
Old Dec 26, 2009 | 03:50 PM
viciousknid's Avatar
Where's the Beef?
does. forgot all about those early models
Old Dec 27, 2009 | 12:30 AM
bohr898's Avatar
Restricted User
im pretty sure the iron heads wouldnt make the swap any more difficult... just heavier.... the crank on the other hand.. prob...... i wonder if you could just shave it down?? and maybe a rethread
Old Dec 27, 2009 | 12:31 AM
bohr898's Avatar
Restricted User
the crank that is
Old Dec 27, 2009 | 01:04 AM
Where's the Beef?
the only reason he mentioned the heads is because the ones with iron heads are the ones with a longer crank. There's a few threads on what to do to make it work but I don't wana look for them right now.
Old Dec 27, 2009 | 01:11 AM
Bullitz400's Avatar
So any certain year lq4 i should look for? May just buy a block and start from scratch. Truck has a procharger right now and I want to keep that on as well. I can just have the ecu tuned for the larger engine and injectors once those are installed as well. So i need a flywheel from a 4.8 ???
Old Dec 27, 2009 | 01:12 AM
any flexplate will work with a normal lq4. Id just look for a lq4 and not piece one together..
Old Dec 27, 2009 | 01:23 AM
Baltimore Whore
Yah, find a complete one and go with it.. Pref a 05 or later as it has the LS2 internals and is a bit stronger then the older years, not that they are not capable of holding or making hp.. A 4.8- 5.3 flex plate will work...
Old Dec 27, 2009 | 01:32 AM
LsxCody's Avatar
i wouldnt even worry about swapping in a 6.0 with iron heads lol
