THBDY coolant bypass?
Old May 15, 2002 | 07:40 AM
11 Second Club
Default THBDY coolant bypass?
Whta tools and hardware do i need to do this.
Any directions would be nice.
I alos just got a new granetelli cold air to replace the Airaid.
thanks
Jason
Old May 15, 2002 | 07:50 AM
BigTex's Avatar
Default Re: THBDY coolant bypass?
You don't need much. I used a 2-way hose connector and a pair of pliers. Both sides had 1/4" nipples I think. Just pull the two hoses off the TB and connect them back w/ the connector. Some people use rubber caps to cap off the in / out on the TB, but I didn't.
Old May 15, 2002 | 08:42 AM
The Knightrider's Avatar
Simple. so simple you'll be shocked. (2) rubber 1/4" caps to cap off both sides of the TB. A 1/4" metal pipe or hose connector about 4"-6" long. And (2) 1/4" hose clamps.
It takes about 5-10 min. to do after you remove you airbox assembly
Old May 15, 2002 | 11:52 AM
you don't have to remove the airbox assembly. just disconnect the intake tube from the TB and gently move it out the way.
keep us updated on the GMS intake. it claims more hp/tq gain the the airraid and K&N. but the GMS MAF also claimed gains and its hurt more people than its help from what i've read.
<small>[ May 15, 2002, 11:54 AM: Message edited by: crazyidiot4.8 ]</small>
Old May 15, 2002 | 03:10 PM
GREGGO's Avatar
Here is what you need and what it looks like:
<img src="http://home.swbell.net/greghud/Image015.jpg" alt=" - " />
<img src="http://home.swbell.net/greghud/Image012a.jpg" alt=" - " />
Old May 15, 2002 | 05:43 PM
11 Second Club
easy enough!
thanks guys
Yah i was going to get DJ motorsports intake in summit but they did have any they are cheaper yet in price.
I think The gran,K&N, and Dj are basically the same
I will g-tech for the gains
6.0l RST
Nov 23, 2015 11:30 AM
bearden86
26
Nov 15, 2015 03:58 PM
sTNT971
Sep 26, 2015 04:22 PM
therock
Jul 25, 2015 09:23 AM
