tbss swap last question?
Old Apr 5, 2011 | 03:34 PM
  #21
AndysC3's Avatar
Originally Posted by 1slowz71
What year of a vette is the fuel filter yoi used ? And can't 0you just put a regulas air filter to that hose it just a breather ain't it ?
look up WIX# 33737. thats the one that Im going to use.
Old Apr 5, 2011 | 03:44 PM
  #22
AndysC3's Avatar
did you manifold already have the seal for the throttle body? The one that goes between the mani and the tb? would you happen the have the part # for that seal? Thanks
Old Apr 5, 2011 | 06:22 PM
  #23
1slowz71's Avatar
does the single out slide rite in to the tbss stock fuel line ?
Old Apr 5, 2011 | 07:12 PM
  #24
1Bear's Avatar
Andy, I don’t know if it’s the same part number or not, but the seal for the 90mm LS2 throttle-body is 12576549. Unfortunately the thing is $43 to figure out whether or not it’s correct. It would be a damn shame if it didn’t work, so I would have to check with someone before I shelled out for it.
Old Apr 5, 2011 | 07:48 PM
  #25
bonj87's Avatar
Originally Posted by LaCamionetaGris
i used the corvette filter for return the gas line and re used my stock injectors.
i have the new EVAP purge valve, i couldnt reuse the stock purge valve, just have to route it properly
the rubber hose comes out the valve cover
ok one thing you need to do , is get that fuel filter OFF the fuel rail.
why? cuz its crimping the return line behind it and affecting your fuel pressure.
how do i know this?
cuz i did the SAME thing..
Old Apr 6, 2011 | 10:23 AM
  #26
AndysC3's Avatar
Post #30 is how I'm going to route mine.
https://www.performancetrucks.net/fo...ht=tbss+intake
Thank Bear for the part number gmpartsdirect had it for 30 shipped.
any idea if that will work on the NNBS intake?
Old Apr 6, 2011 | 10:25 AM
  #27
1slowz71's Avatar
So bon how did you take care of the return line being pinched ?
Old Apr 6, 2011 | 11:20 AM
  #28
LaCamionetaGris's Avatar
yup this is the exact fiter i went with works perfectly, and it just slides into the tbss fuel rail without problems.
yes TBSS already came with it. dont know thw part#
Old Apr 6, 2011 | 11:26 AM
  #29
bonj87's Avatar
that filter, on the tbss rails doesnt quite slide RIGHT in.. you have to bend the rail slightly to get it to fit.
to answer what i did.. you get a 18 inch length of fuel line, one end female.. shove that on the rail, the other end a mail an fitting,, slide that into the fuel filter and zip tie it in place.. that pulls the lines AWAY from the firewall and then they arent pinched.
the 33737 is female on the front, dual males on the back.
Old Apr 6, 2011 | 11:31 AM
  #30
bonj87's Avatar
here is what mine looks like,, but this is not my pic.
