tbss swap last question?
Old Apr 5, 2011 | 01:08 PM
mhotrodscooter's Avatar
Go from the valve cover vent to the intake tube. It doesn't matter if you don't have a flat spot or not. Just connect it the best way you know how..
Mine after swap
Old Apr 5, 2011 | 01:10 PM
LaCamionetaGris's Avatar
yes i gotta clean it up where did bolt on the x link, i thought the vortec cover would bolt on looks good
Old Apr 5, 2011 | 01:12 PM
so do i plug the hole on the intake then?
FINALLY REACECHED THE 100 POST MARK
Old Apr 5, 2011 | 01:17 PM
I don't have my truck or pictures to show how it's done.. I mounted link to a bolt on passengerside of intake on top right behind tb a little ways. I made a L shape bracket.
Old Apr 5, 2011 | 01:23 PM
What hole in intake or you talking about?
Old Apr 5, 2011 | 01:33 PM
Dezert1500's Avatar
Yes, plug the hole on the intake. That hole is meant for the valley cover breather line that comes off GenIV's valley cover.
Tap the intake tube and run a vacuum tube from the passenger valve cover to it.
Old Apr 5, 2011 | 01:42 PM
Dezert1500's Avatar
This is the only pic I have and it's hard to tell, but you can see where I ran the vacuum line to the intake tube.
Here's the kit I used. Spectre Part# 9712
Old Apr 5, 2011 | 02:34 PM
AndysC3's Avatar
so for this, all you did was drill a hole in the intake tube and use the correct fitting? any leaks?
Old Apr 5, 2011 | 03:30 PM
1slowz71's Avatar
What year of a vette is the fuel filter yoi used ? And can't 0you just put a regulas air filter to that hose it just a breather ain't it ?
Old Apr 5, 2011 | 03:31 PM
Dezert1500's Avatar
Zero leaks, just make sure the hole is drilled to the correct size.
