tbss/ssr intake for drive by cable
Old Mar 31, 2008 | 04:01 PM
Default tbss/ssr intake for drive by cable
ok so here is the problem i have read so much stuff my head is about to explode on the swap. so i have a cable driven throttle body instead of a crive by wire . so i need to know every thing needed the more help the better tryin to get th 6.0 in and get this intake for the cam. help will be appreciated.
Old Mar 31, 2008 | 04:13 PM
thunder550's Avatar
High on diesel fumes
Make your own throttle cable bracket. It's not difficult. Mine's not pretty, but I didn't spend a lot of time on it.
Old Mar 31, 2008 | 04:43 PM
what about the throttle body which one are you using 90mm or 78mm/ also what injectors and fuel rail are you using ? and could you tell any difference on the upper rpms cause im going to be running a 232 / 236 magic stick v1 on a 112 lsa
Old Mar 31, 2008 | 04:52 PM
thunder550's Avatar
Throttle body is a UMI 90mm. Using Acceleronics 96# injectors (LS1 style, taller than standard truck injectors) and the stock truck fuel rails and crossover modified to fit. Pics below.
Take a look at the flow data below. That's all the info I have about it. I did the SSR manifold when I did the new 408, so I didn't get any good back to back feel or numbers on the same engine.
Old Mar 31, 2008 | 05:00 PM
thanks for the info you got a linc for the umi or does a sponsor sell them on here.
Old Mar 31, 2008 | 05:08 PM
thunder550's Avatar
Can't post a link since they are not a sponsor. Do a google search for UMI Racing.
ARC
57
Feb 21, 2022 10:54 AM
jdb11386
Dec 3, 2015 09:34 PM
TimDave217
Aug 24, 2015 04:38 PM
Suburban2500
Jul 14, 2015 02:10 AM
