Tbss problems!
Old Dec 10, 2011 | 09:54 AM
youngbuck's Avatar
Default Tbss problems!
Ok so I did the tbss swap with a nnbs throttle body, I'm finally getting it tuned an my tuner says it is showing 100% at 3/4 throttle an when you do floor it the comp looses connection to the tps, truck goes crazy an into limp mode. It's even showing 13% throttle at idle or the truck off. I have the xlink, any thoughts? Truck is my dd.
Old Dec 10, 2011 | 10:19 AM
mhotrodscooter's Avatar
Is the pink wires on the x-link still together or cut?
Old Dec 10, 2011 | 03:55 PM
youngbuck's Avatar
There still together.
Old Dec 10, 2011 | 05:52 PM
Which TB or you using?
Old Dec 10, 2011 | 07:40 PM
youngbuck's Avatar
I was told it was a nnbs truck tb.
Old Dec 10, 2011 | 09:47 PM
Could you post a pic? Some TB require the pink wires to be cut & some not. When I installed my 90mm tb I miss read the direction & cut the pink wires & it did the same thing that yours is doing
Old Dec 10, 2011 | 10:05 PM
youngbuck's Avatar
Link below. Should I just cut the pink wire an see if it works? It's delaying me getting it back an it's my dd.
Old Dec 10, 2011 | 10:06 PM
youngbuck's Avatar
90mm L92 DBW Throttle Body - LS1TECH
Old Dec 10, 2011 | 10:11 PM
1slowz71's Avatar
the throttle body could be bad 05gmcsierra had a similar problem ,
Does it look like this
If so it shouldn't need pink wires cut. It could just be a bad tps in the tb.
