TBSS intakes
Old May 30, 2012 | 04:49 PM
nwalton29's Avatar
Default TBSS intakes
How are the TBSS intakes different than other truck intakes?
Old May 30, 2012 | 06:29 PM
Cknox121's Avatar
They are a little bigger then the nbs intakes. The nnbs intakes are supposed to be the same as the TBSS intakes.
I have one forsale if interested.
Old May 30, 2012 | 09:43 PM
okieraptor's Avatar
bigger as in the runners are larger? Thats better for torque right?
Old May 30, 2012 | 10:56 PM
rjwz28's Avatar
Man Motor club
Larger throttle body opening is one difference for sure. I'm not sure otherwise.
Old May 31, 2012 | 02:33 AM
AndysC3's Avatar
The 4 bolt 90mm tb opening on the tbss/nnbs intake is the biggest difference.
Old Jun 1, 2012 | 07:35 AM
gmc6.0's Avatar
Will those bolt up to 317 heads??
Old Jun 1, 2012 | 11:37 AM
rjwz28's Avatar
Man Motor club
Yes, as long as it comes from a 4.8/5.3 truck or a TBSS.
Old Jun 1, 2012 | 09:50 PM
AndysC3's Avatar
Yep, if it has the rectangular intake ports its for the L92 engine or the nnbs 6.0l and will need the l92 heads. The tbss intake has the cathedral intake ports and will bolt right up. Depending on the year of your truck it could be return style or returnless. The tbss intakes have a returnless style fuel rail.
Old Jun 4, 2012 | 12:37 AM
Vortec350ss's Avatar
I'm not sure the runners are that much larger, but the intake port is a lot bigger as everyone else already mentioned in 90mm vs. 78mm. The volume of the intake is also a lot larger too, it flows a lot more air than the stock intake can.
Old Jun 4, 2012 | 11:43 AM
Ferocity02's Avatar
Are there any cable throttle bodies out there that will work on a TBSS intake? I'm interested in swapping one into my '01 5.3L.
Does the TBSS or NBSS intake have an EGR port?
