TBSS Intake VS SSR Intake
Old Mar 4, 2013 | 07:28 PM
TRD_Tundra's Avatar
Default TBSS Intake VS SSR Intake
I just picked up an SSR intake and a 92mm Nick Williams TB for a good price, The intake looks identical to a NBS intake except the MAP sensor goes more towards the front and the 4-bolt 90mm Throttle Body inlet.
Question is if their is a big difference between the SSR intake and the TBSS intake, is the hassle worth the HP gain for the TBSS intake compared to the SSR?
This intake is going on a 2000 Silverado 6.0 singlecab
Old Mar 5, 2013 | 12:07 AM
chevyboy.520's Avatar
That's cool, i didn't know the ssr had a 4 bolt tb? What engine was that on? 6.0 or 5.3?
Old Mar 5, 2013 | 09:36 AM
TRD_Tundra's Avatar
Not sure of what engine it came off, does it make a difference?
Old Mar 5, 2013 | 10:02 AM
I'm sure it doesn't flow as much as a TBSS or nnbs but the fact that it has a 4 bolt tb is awesome. If you have it, I'd run it
Old Mar 5, 2013 | 09:30 PM
TRD_Tundra's Avatar
Anyone ever used an SSR over the stock intake?
Old Mar 5, 2013 | 10:53 PM
skolman91's Avatar
Looks to be the exact same as a reg truck intake besides the 4bolt TB which is a plus and would help a little id imagine, but i was always under the assumption that the tbss made more power because of the larger plenum area and runners, which if you look their is a difference between intakes..
Old Mar 7, 2013 | 12:02 PM
ontarioss's Avatar
TBSS and SSR intakes are the same.
Old Mar 7, 2013 | 12:43 PM
lt1 sport's Avatar
^Not totally, the SSR with Gen 3 engines still had the gen 3 manifold which is what that is, in 05 when they got the gen 4 then they had the TBSS intake, which should actually be called the gen 4 truck intake because all gen 4 truck engines recieved the intake no matter what the year. There would still be a benefit of finding a gen4/TBSS intake, just look at one once you can see the difference in the manifold size and runners. The one you have obviously looks nearly identical.
Old Mar 7, 2013 | 10:15 PM
ontarioss's Avatar
Sorry, You are right I forgot to mention 05 and 06 only with the ls2 engines.
lucas287
31
Jan 12, 2021 06:18 AM
chvy=power
Sep 8, 2015 11:06 AM
USMCvet0311
Sep 4, 2015 09:43 PM
lxcoupe
Sep 2, 2015 12:58 AM
04450r
Jul 24, 2015 01:58 AM
