Is this the TBSS intake i need?
Old Oct 19, 2016 | 03:38 PM
marineusmc4's Avatar
Originally Posted by 86 IROC
Not sure why people don't run the GMT900/TBSS rails, it was simple and cheap. I bought my complete 2011 intake manifold, minus TB for $125. My TB was more expensive than the whole intake swap.
See I have the TB...can't remember for the life of me where I got it but researched the number and that's the one I need. The tbss intakes are around 140 new on eBay. I might check on fuel rails too. I'd rather get it all setup off the truck beings it's my DD than to dick around with making it work within a certain timeframe and dealing with Murphy's law. So the tbss/nnbs rails are the same correct?
Old Oct 19, 2016 | 05:25 PM
10 Second Club
I assume that they are the same. Here is what mine looks like.
Attached Thumbnails Is this the TBSS intake i need?-img_20160324_113138194_hdr_8fe9b80a50c078e5d66dda9a9567e7f5e8aa4fe4.jpg   Is this the TBSS intake i need?-img_20160313_163908541.jpg
Old Oct 20, 2016 | 01:56 PM
NorCalAnthony's Avatar
Remember all of the Gen IV 4.8's and 5.3's got the same intake as the TBSS and if you can find one off a flex fuel truck it should come with 36# injectors instead of the stock TBSS injectors that are 29#. If you still have the stock '03 5.3 injectors on your truck I think they're around 25# so either should be an upgrade for you. FWIW I found my TBSS intake for $140 (w/TB, injectors, fuel rails, and sensors) and then picked up a new set of the 36# injectors for $55 off ebay.
Old Oct 20, 2016 | 02:48 PM
ya i usually dont have good luck with "deals" lol. im usually too late when i find them. i looked last night at nnbs rails on ebay and just for a set of used rails they were like 230. i might just find some aftermarket rails to run if thats the case. i put up a post in the WTB section so maybe someone will see it.
Old Oct 20, 2016 | 03:10 PM
turboal1's Avatar
Default T/b
Run the stock 87mm t/b it's more than enough
for a 5.3. you can remove that lump on the bottom
and pretty it up for a smoother air flow.
Old Oct 20, 2016 | 03:46 PM
you mean 78 right? the stock size is 78 and the 4 bolt is 87. but ill prolly run the 87 since this will be a forced induction build. but yes i will still port and polish the one i end up using
Old Oct 20, 2016 | 03:53 PM
well talking to a guy right now that has a fully setup intake minus the TB which is perfect. so hopefully we get it sorted out and ill get that tbss intake like everyone else and add 128,091,987,833,718hp to my truck lmao
Old Oct 20, 2016 | 04:32 PM
Sweet good luck with the sale
Old Oct 20, 2016 | 04:36 PM
ya, no go on the sale he doesnt even have it lol.
Old Oct 22, 2016 | 07:41 PM
Gbrown1320's Avatar
The only thing that needs to be accounted for, is that the flex fuel equipped trucks had a different fuel rail to accommodate the taller flex fuel injectors. If you plan to use another (shorter) injector with that rail, you may need injector spacers to make up the difference in height. The non flex fuel trucks came with rails that were the correct height to retain your shorter oem 99-07 injectors.
