TBSS intake guys, with aftermarket rails ??
I'll try to get you a measurement when I get home today.
I was running the intake when it was dyno'd. It made 404/391. Thats with a 230/236 .581/.581 114 comp cam. 3.42 gear, 32" tire (came on the truck).
Here's a link to my dyno thread. I don't have the dynosheet attachment on my I drive at work.
https://www.performancetrucks.net/fo...d.php?t=472581
Hmm. What needed to be modified? Shaving the mounting post down? How tall were the injectors? The fast injectors are slightly shorter than my stock injectors. Thanks. Found some 1/2" spacers but were kinda pricey.
Yeah, had to grind down the mounting posts. Quick work with a flap disc on a grinder, but be sure to use an old disc...the plastic clogs them up. They are the long injectors.
Its a little more of a pain in the *** with longer injectors, as they lean towards the posts more and you have to grind the posts, otherwise the injectors don't seat right. Yours looks real clean though.
Better pics coming when I get everything in place and tightened up
Also, there seems to be something wrong with your turbo too, it keeps choking...you need a bigger one
