TB Mods
Old Jun 2, 2002 | 02:30 AM
rphinney's Avatar
Default TB Mods
The other day I was on a camaro tech page and saw a how-to on a mod that allows the TB to open the buttefly more by grinding at the bump stop on the TB linkage . Has any one tried it? also What is involved in porting or polishing the TB? Can I do it or will it cost me some bucks?
Old Jun 2, 2002 | 03:04 AM
GREGGO's Avatar
Default Re: TB Mods
As far as the bump stop grind goes, you will need Auto-tap to help you in that, so you don't go to far with it, or so I have heard. I have not done that one. On the portrd T/B, one of our site sponsors "Jantzer Performance" can help you there. Unless you are good with a dremal, let someone do it. I had mine done by someone that knows a lot about a certain popular Vortec motor <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> . I did notice quicker throttle response after I installed it.
Old Jun 2, 2002 | 04:04 AM
DV8's Avatar
DV8
Default Re: TB Mods
I just did this on my buddy's 4.8 GMC and it's the same as the 5.7 LS1. You could use a voltmeter if you don't have the auto-tap and just grind it down to 4.65 volts since the limit is 4.7.
Hope this helps.
Old Jun 2, 2002 | 04:06 PM
CashDudeHomie's Avatar
Default Re: TB Mods
Where do you connect the voltmeter at?
Old Jun 3, 2002 | 12:31 AM
rphinney's Avatar
Default Re: TB Mods
Yeh where does that voltmeter go?
Old Jun 3, 2002 | 08:53 AM
DV8's Avatar
DV8
Default Re: TB Mods
If you were to look at the TB from the front of the truck there are two wire harnesses on the right side. The bottom one is the TPS which has three wires forming a T pattern. The base of the T is the wire that you want to poke into (Blue wire on a 2000 GMC). Once you tap into it with the key on the "On" position, you place your ground and open the TB by hand (requires about 3 hands) and read the voltage. Typical voltage from factory that I have seen is about 4.4 V. You just grind the bump stop until you reach 4.6-4.65 V. *Warning* if you go past 4.7 V. you will throw a code. If you guys would like some photos, I'll try to take some in the evening and post them up.
Hope this helps.
Old Jun 3, 2002 | 02:10 PM
rphinney's Avatar
Default Re: TB Mods
photos always help thanx for the info! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jun 4, 2002 | 10:53 AM
Liquid_Blue's Avatar
Default Re: TB Mods
I'll see what we can do about the photos. We used a real accurate volt-meter, to my surprise. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> The mod only took around 45 minutes to complete and it really made a difference at WOT and from a stop. Johnny let me know when you want to take the pictures sometime today or later this week.
Old Jun 4, 2002 | 08:53 PM
DV8's Avatar
DV8
Default Re: TB Mods
That's cool, I just took a pic of my TB. Here are is a quick pic of the TB.
<img src="http://users2.ev1.net/~johnnydoris/TB.jpg" alt=" - " />
madmann26
Apr 29, 2020 09:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
bisqikss
Sep 27, 2015 09:40 PM
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
