TB mod
Old Jan 21, 2003 | 04:05 PM
speeder_08's Avatar
Default TB mod
how much should i shave on the stop to get the tb to open to 90 degrees? <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Jan 21, 2003 | 04:08 PM
Texas Terminator's Avatar
11 Second Club
Default Re: TB mod
the idea is to obtain true WOT readings to your ECM. you will need to use EASE or ATAP to check your readings. you can do it with a meter too if you know how.
Old Jan 21, 2003 | 04:12 PM
speeder_08's Avatar
Default Re: TB mod
i don't know what a EASE or ATAP is help me out!
Old Jan 21, 2003 | 04:40 PM
Default Re: TB mod
Ok, there is a blue wire thats part of the TPS. You will need to tap the + lead on your Multimeter to it. Then connect the black lead to ground (- of bat term works great.) with the Key in the run position, but the motor not running open the throttle it will give you a read of like 4.1 or 4.2. Slowy grind the TB stop until it reads 4.6v @WOT. If you go past 4.69999v youll set a code. good luck, J
Old Jan 21, 2003 | 04:44 PM
11 Second Club
Default Re: TB mod
analyzer software. both can be had for about $350 or so. see www.obd2.com or www.autotap.com to check out therir stuff. i have the EASE software for two reasons, one, i have head alot of people complain that the ATAP doesn't always give good readings or work right at all, and two, EASE has a hand in designing GM's software.
Old Jan 21, 2003 | 07:15 PM
speeder_08's Avatar
Default Re: TB mod
What if u grind to far?
Old Jan 21, 2003 | 08:41 PM
BigKID's Avatar
Default Re: TB mod
You will have to get some epoxy to fix it or get a new TB. If the tps voltage reaches 4.7V the ecm will scence something is wrong and set a code and possible go in to limp mode.
Old Jan 22, 2003 | 09:25 AM
Boost13r's Avatar
Default Re: TB mod
I've just set mine to 4.64v,has any body done a back to back comparison at the track or on a dyno to see real gains?
Old Jan 22, 2003 | 11:19 AM
Scream's Avatar
MOOBIES Moderator
Default Re: TB mod
I had a buddy of mine hook his Diablo Sport programmer to my truck (we couldn't tune it but it still gives real-time readings) and it said that my TPS was at 100%. Would that mean that I wouldn't benefit from this mod?
Old Jan 31, 2003 | 07:02 PM
eallanboggs's Avatar
Default Re: TB mod
Grind a little at a time and check the voltage reading often. Use a Digital VOM. Stick a tiny sewing needle into the blue wire to get your reading. When you get close to 4.64 VDC STOP grinding. Make your final adjustment by bending the cam tab a little. Use a vise grip to bend the tab and when I say bend it a little I mean a LITTLE till you get it within a couple of hundreths of 4.64 VDC. You can actually get it to exactly 4.64 VDC if your good. You should also set the closed throttle value to 0.60 VDC with the torx screw.
madmann26
Apr 29, 2020 09:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
bisqikss
Sep 27, 2015 09:40 PM
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
