tb for marine intake
Old Mar 24, 2006 | 01:45 PM
Default tb for marine intake
whats the biggest tb you can use for the marine intake?
Old Mar 24, 2006 | 06:17 PM
hog's Avatar
hog
Stock is 75 mm, you can borethat sucker to whatever you want. On ebay i think I saw a 78 mm and 85 mm converted from LS1 T-bodies??
peace
HOG
Old Mar 25, 2006 | 08:23 AM
99kon's Avatar
what is the part number for that marine intake
cant find it anywhere
Old Mar 25, 2006 | 08:03 PM
Question
What is the marine intake being used on? Vehicle or boat?
Only reason I ask is because I've seen people use Mercruiser blocks and electronics in some mild race cars. They even had the Mercruiser engine cover on it.
Jim
Old Mar 25, 2006 | 08:43 PM
James B.'s Avatar
You won't get any gains porting the throttle body or installing a larger on the Marine L31 Intake. It will do just fine with the 78mm throttle body. The manifold itself flows much better than the stock one at high RPM and the large internal volume makes air flow through the throttle body efficient. I do recommend removing the EGR diffuser plate from the throttle body blade since there's no EGR blowing against the bottom of it.
Old Mar 26, 2006 | 10:53 AM
cool I'll just use the stock vortec throttle body and remove the diffuser. thanks for the help guys.
chvy=power
Oct 20, 2015 09:08 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
turbo truck
Sep 2, 2015 09:58 PM
lxcoupe
Sep 2, 2015 12:58 AM
