TB bypass?
Old Apr 26, 2005 | 07:51 PM
2000 SILVERADO's Avatar
Default TB bypass?
What should I use to connect the TB hoses together? And can I get this somewhere like autozone?
Old Apr 26, 2005 | 07:59 PM
v8
17,16,15,14,13,12,11 Drvr
yes you can get it from autozone, use a 1/4" hose butt splice. or hose to hose connector.
Old Apr 26, 2005 | 08:28 PM
Cool thanks, just wanted to make sure.
Old Apr 26, 2005 | 09:04 PM
thunder550's Avatar
High on diesel fumes
I just did mine this weekend, using exactly that. 1/4" to 1/4" hose butt splice, came with 2 hose clamps, then bought a pack of 1/4" vacuum caps to seal off the TB. Something like $6 total. Don't pull the hoses off hot! I let mine cool for about 45 mins (not enough) and pulled one side off. Still under pressure, got hot coolant to squirt all over my hand OUCH.
Old Apr 26, 2005 | 09:10 PM
user 108208932024's Avatar
Banned
Attach the end that goes to the radiator (now that you have taken it from the left side of the TB facing the truck) to the top of the engine where the right hose went to. There is enough to make it work.
Old Apr 26, 2005 | 09:43 PM
Are't you suppost to partly drain the coolant?
Old Apr 26, 2005 | 10:45 PM
Sleepy53's Avatar
I didn't but I had a plastic cup and some rags ready if some coolant came out. Only a small amount of coolant spilled out.
Old Apr 27, 2005 | 12:20 AM
PappyDan's Avatar
Tribe Shaman
this is where vise grips come in handy,
loosen the belt, take out the bolt on the alternator next to the TB, get it out of the way,
pinch the hose on the right side as far away from the TB as you can get, then do the left side, take off the coolant cap to release any pressure, now remove the hoses and just reconnect them with the butt connector and put everything back, now your done with no coolant loss.
Old Apr 27, 2005 | 10:08 AM
flynn78us's Avatar
so what kind of gains can I get from doing this?
Old Apr 27, 2005 | 10:24 AM
dewmanshu's Avatar
Moderately Differentiated
it's a controversial mod. The cooler your internal air the less the computer will take from your timing. More timing equals more power. That's not a theory, that's fact. But I haven't seen anyone post any numbers of how much less your IAT is. It's a good mod for warm weather guys like in Texas. The closer to the north during winter months your throttle blade might start to stick because the coming into your throttle body is so cold...small chance, but GM obviously thinks it's necessary to keep your throttle bottle a little warm just in case.
