TB bypass
Old Jan 9, 2005 | 01:43 AM
dragonman0325's Avatar
Default TB bypass
Does this actually help add more power and how is it acheieved. I searches around but have'nt found much. Thanks for the help!
Old Jan 9, 2005 | 01:45 AM
BlownChevy's Avatar
blownerator
25 Year Member
Abosolutely no RWHP to be found there. But it does look better without the hoses running up to it.
CAMMIN03''s Avatar
Banned
I was wondering the same thing...... Thanks....
Old Jan 9, 2005 | 08:00 AM
I recently did this mod only because my throttle body is now relocated because of the whipple and the throttle cable was rubbing a hole in the hose. now that the hose is gone, no problem.
Old Jan 9, 2005 | 09:50 AM
bodyguard6799's Avatar
Did you completly remove the hoses?? What did you use to plug the holes??
Old Jan 9, 2005 | 11:10 AM
don't need to plug the holes
Old Jan 9, 2005 | 11:32 AM
I'm not talking about the lines comming off of the TB, I'm talking about the line on the radiator and the intake. I just took the hose comming from the radiator and connected it straight to the line on the intake.
Old Jan 9, 2005 | 02:22 PM
sounds right. there is a line that comes out of the top of the engine and in to the TB, then another line that comes out of the TB and in to the radiator. All you do is make the line go out of the top of the engine and in to the radiator. you do remove one hose all together. There isn't anything to plug other than the barbs on the TB, but, that's not necessary. I hope that makes sense.
Old Jan 9, 2005 | 03:36 PM
Yeah, thats exactly what did, it just sounded like you removed the hoses all together, I was just wondering if that was possible.
Jake99
Aug 8, 2015 07:56 AM
therock
Jul 25, 2015 09:23 AM
lxcoupe
Jul 21, 2015 02:12 AM
Ferocity02
Jul 17, 2015 07:05 PM
