rough idle triggered SES light
Old Jan 8, 2005 | 01:23 PM
KeukaZ71's Avatar
Default rough idle triggered SES light
drove my truck around last night. later on when i came to a stop at stoplights, i notice my truck idling kind a rough. it was a slightly rough. didn't feel like it was going to stall though. the rpm's seemed ok. at cruising speeds it ran smooth. so i am pretty sure it is not the plugs and wires. then eventually the SES light came on, so i knew something was definitely wrong. my truck had problems stalling out about a month ago right after starting it. so i clean the idle air control valve. then it worked fine. so here are a few things i think it might be, any feedback from you guys would be appreciated.
- bad IAC valve
- bad fuel pump
- loose intake tube
BTW, i have a descreened MAF, but it has never been a problem in the last 2 years i took it out
Old Jan 9, 2005 | 08:57 AM
KeukaZ71's Avatar
ttt !!!!!!!!!!
Old Jan 9, 2005 | 09:00 AM
one03sierra's Avatar
Formerly one92rs
Talking
is there someone that can read the code for you. that would get you headed in the right direction.
Old Jan 9, 2005 | 11:36 AM
badpewter-z's Avatar
LS1TECH Sponsor
was it running rough like it had a cam almost??
probbly got a multible cylinder misfire code which could actully be a bad plug or wire you wouldnt really notice a misfire here and there while crusing but the stupid computer will pick it up .
Old Jan 9, 2005 | 04:13 PM
KeukaZ71's Avatar
i'll probably take it to autozone to get it scanned.
smokeshow
Aug 23, 2015 08:23 PM
Suburbazine
Aug 9, 2015 01:17 AM
rojeho
Aug 8, 2015 07:20 PM
Ferocity02
Jul 17, 2015 07:05 PM
GreyChevy
Jul 7, 2015 08:57 PM
