Tapping on startup / passenger's side
Old Jul 4, 2011 | 06:49 AM
03RCSB's Avatar
Default Tapping on startup / passenger's side
I searched for a couple of days for something on this and it seems that people are either having piston slap or the constant tapping of a bad lifter but I'm seeing something different.
I swapped in a tr220 cam a few weeks back and everything was fine for the first few days but now on a cold start I get a pretty loud tapping from the passenger's side on a cold start. The tapping goes away within 3-5 seconds once the oil pumps up and it will not come back for the remainder of the drive.
Any thoughts on what it could be? It's loud and doesn't sound good. I've already pulled the valve cover and everything looks fine so.
Thanks
Old Jul 4, 2011 | 07:24 AM
bgray's Avatar
TOTM: June 2007
I would replace with ls7 lifters and see how it goes. These guys are notorious for grenading a lifter, and when a lifter goes bad, usually soon after the engine will be bad
Old Jul 4, 2011 | 08:17 AM
03RCSB's Avatar
That's what I was afraid of but from what I had read a bad lifter will make noise all the time. Since my tick only happens on start up and goes away within three to five seconds, I was hoping it was something else.
Old Jul 4, 2011 | 08:43 AM
TIM Z's Avatar
11 sec. Truck Mod
How many miles on your lifters now?
It does sound like a lifter, i would replace them.
Old Jul 4, 2011 | 12:48 PM
03RCSB's Avatar
about 105k on the current lifters
Old Jul 4, 2011 | 04:10 PM
TIM Z's Avatar
11 sec. Truck Mod
Replace the lifters my friend.
Old Jul 4, 2011 | 07:16 PM
bbc4542001's Avatar
my lq4 started tickin on start up before i change some stuff,i added .100 longer push rod and it never did it again
Old Jul 4, 2011 | 07:25 PM
CashDudeHomie's Avatar
If it goes away after a couple seconds, it's probably not a big deal. It takes a second for the oil system to fully pressurize.
I would not replace lifters until one completely fails. It is a total PITA. Other people may think differently though; this is just my opinion.
Old Jul 4, 2011 | 07:57 PM
03RCSB's Avatar
Thanks for the input guys. I've seen a few posts about guys using a little bit of trans fluid in the oil to clean the lifters so I might go that route and see if it helps. If it doesnt I guess I will keep a close eye on it and replace the lifters if it gets worse
walledition
Feb 24, 2026 03:27 PM
GM1697
Sep 9, 2015 10:31 PM
muncie21
Sep 7, 2015 09:55 PM
madmann26
Sep 7, 2015 06:41 PM
xerox17
Sep 5, 2015 01:23 PM
