take a shot at this engine noise
Old Jun 23, 2015 | 08:52 PM
ls1prayer's Avatar
Default take a shot at this engine noise
U can only hear this particular noise inside of truck not under hood
https://youtu.be/mvwnsh8wJ7M
Old Jun 24, 2015 | 05:35 AM
cams 98 silverado's Avatar
First thing that came to mind is interference from the engine to the speakers.
Some vehicles come with a wired in resistor to clean the power up from the battery.
Years ago in my dads 97 c1500 he put in an old style hands free with the corded mic and speaker that plugged into the cig lighter. As he drove, the speaker unit made that high pitched whirring noise and it got louder with revs. It was the injector pulses that were being picked up. Just my 2 pennies.
Old Jun 24, 2015 | 06:34 AM
treylittlefield's Avatar
Does it cut in and out or change with rpm?
Old Jun 24, 2015 | 11:31 AM
ls1prayer's Avatar
Default hey
Yes it changes with rpm. And if i change the load on it. It quiets are gets louder. My 1st thought was tourque converter bolts lose. But its top of the motor or bell housing area. And for some reason my valves are starting to chatter more any thoughts?
Old Jun 24, 2015 | 12:06 PM
So your for sure its not coming from the speakers I guess?
Old Jun 24, 2015 | 01:35 PM
ls1prayer's Avatar
Pretty sure. Its like right in front of radio. But a knocking sound so weird knoe 1 can really pin point it. 3 shops iv taken it to.
Old Jun 24, 2015 | 10:41 PM
natejk's Avatar
8 Second Truck Club
Blend door slapping? Just a thought can you get a better video
Old Jun 25, 2015 | 09:35 AM
GMC93's Avatar
I thought the same thing but he said that it changes with RPM.... hmmm idk
Old Jun 25, 2015 | 09:42 AM
Gadgetized's Avatar
Do you have a stethoscope? If not you can use a clean extension. Put it on the engine and in your ear. Keep moving it around the engine until you find it. Sounds funny but it works.
Old Jun 25, 2015 | 10:20 AM
GMC93's Avatar
Also maybe disconnect the serpentine belt to confirm that it isn't any of your accessories making noises.
