Switch to synthetic oil after 100000 miles?
As long as it was previously maintained with a quality detergent oil, I see no reason that switching to synthetic will be a problem. I am running mobil one on mine after 100K with no issues and I don't know the maintenance history of the engine before I bought it at ~95K miles.
The only time I think you will see a problem switching oils is if the engine has seen years of non-detergent type oil in it. Then if it is switched to a detergent oil that cleans all the deposits out it will start leaking.
I've run pennzoil 10w30 from 62000[when I bought it]to 105000 now.With my new Procharger set-up running 12psi of boost at 5900 rpms I thought I should switch.I don't know if pennzoil is a detergent oil.If there could be a problem I'll just leave it alone.
Most all multi-weight oils today are detergent oils. That being said pennzoil is widely discussed as being a nasty sludge leaving oil that clogs and destroys engines. I'm sure the formula has changed from the old days and that may all just be a rumor to begin with. Either way I don't here near as many bad things about other oils so I won't touch the yellow bottle. Castol and Valvoline are generally percieved as better choices for conventional oil. IMHO.
As far as conventional vs. synthetic oil goes it really doesn't much matter as long as your change intervals are reasonable. That seems to be the main benefit of syns is the extended change interval.
i dont think there will be any problem switching to synhetic. i did the same thing starting at 80K, now i use the royal purple, the one for boost and ntrous apps., and i like it alot. its really just peace of mind for me.
Noah Burns
Sep 7, 2015 05:50 PM
