swapping truck intake
Old May 7, 2012 | 09:36 PM
squrrielsz71's Avatar
Default swapping truck intake
i have an 5.3L 03 sierra with a return fuel system with a vaccum regulator. would i be able too swap an intake off an 04' with a returnless fuel system without the vaccum regulator by adding a aftermarket regulator?
Old May 8, 2012 | 05:46 AM
TXSZ66AVLANCHE's Avatar
Of course you can, but I don't understand what you will gain from it.
Old May 8, 2012 | 06:20 PM
i too smooth the intake and add some aftermarket fuel rails just too clean up the look under the hood. the intake on my truck now has a vaccum fuel pressure regulator. i have another intake that i would like too do all the work on and then bolt all the pieces on at the same time but this intake has a returnless fuel system. just wondering if i will run into any problems. i will add an afermarket fuel pressure regulator.
Old May 8, 2012 | 06:27 PM
aaronmc's Avatar
Alot of work to have the same thing in the end. If your going to switch to aftermarket rails and regulator why not switch to an ls6 or fast intake which is already smooth.
Old May 8, 2012 | 07:19 PM
im not really looking to gain performance. just want too clean up under the hood without having too tune it or spend alot of money.
Old May 8, 2012 | 08:12 PM
aaronmc's Avatar
Even smoothed and painted the truck intake still looks like a turd. Sure it looks better but compared to some of the aftermarket intakes If I were going for a clean look I would just swap it.
TA63
Mar 29, 2016 04:38 PM
Slammed96
Jul 27, 2015 07:22 AM
Ketis
Jul 23, 2015 12:37 PM
black6spdz
Jul 16, 2015 01:32 AM
jrplz
Jul 9, 2015 12:07 AM
