swap help v6 to 6.0
Old Mar 3, 2013 | 07:18 PM
FcoRojas's Avatar
Default swap help v6 to 6.0
Hey guys I know I know this subject has been covered already but not in much detail here is the sketch.
I bought a 04 yukon denali 2wd with the awesome 6.0 it runs everything works I know its basically an easy swap from what ive researched im putting that engine in my 03 silverado single cab that came with the punk *** 4.3 only question I have is will I need new fuel lines? Aswell as a bigger gas pump? The one in the denali went out. Any help and advice would be awesome!! Thanks
Old Mar 3, 2013 | 07:27 PM
skeet's Avatar
gas lines and pump will work fine, youll probaby beable to get away with using the yukon motor/frame mounts also. just swap it all over it'll work
Old Mar 3, 2013 | 09:15 PM
FcoRojas's Avatar
Alright I was making sure because I read in a thread that the v8 has a return fuel line and the v6 doesnt or some **** like that ill link it here when I find it it was from this site itself.
Yea should be easy i will start taking it out tomorrow the tranny mounts up the same right? Or do I need new mounts for that as well im taking them both out in 1 piece also will I have to get a different drive shaft?
Old Mar 3, 2013 | 10:01 PM
skeet's Avatar
nope your trans will bolt up and driveshaft will work
Bumpers
Aug 4, 2024 09:44 PM
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
OHsixLS3
Dec 27, 2016 09:30 AM
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
