Supercharger Info?
Old Jan 29, 2004 | 10:55 PM
sloblaze's Avatar
Default Supercharger Info?
Okay I am looking to put an ATI procharger on my truck I just need to know what kind of tuning is required and if I need to step up to some 42# injectors, and if there is any problem with the ATI on a 5.3 like belt slip when you change pullies, or anything else, like will I have to beef up my 4l60 or should I swap to a 4l65?? Thanks.
-Pete-
Old Jan 30, 2004 | 06:07 AM
Superchargers and 4L60s don't usually mix too well. You'll be fine with what you have for a while, just depends how you drive it. If you are always in boostville, well.......?
Old Jan 30, 2004 | 10:39 AM
Black Blown 02's Avatar
-Pete-
I'd say you should get EFI live, EDIT, and a wideband if you are going to go above 8psi.
If just 8psi, you could probably get away with just EFIlive to monitor KR and 02 voltages.
I went with a Reichard Racing pulley and a Goodyear Gatorback belt when I stepped up to 11psi. Belt slip isn't much of an issue.
My stock trans with just a shift kit lasted until my first drive with the 11psi pulley.
Old Jan 30, 2004 | 10:47 AM
you will need to beef up the tranny. most definetly servos, shift kit and new clutch packs. it wont last long.
Old Jan 30, 2004 | 11:34 AM
onyx's Avatar
14 Second Truck Club
i'll be running my 4L60E w/ the RADIX, then wait for it to die on me... of course i'll be putting all the tranny goodies in it to... hopefully it will last a bit.
Old Jan 30, 2004 | 12:18 PM
tbyrne's Avatar
It would be best to order the kit with no FMU then go with 42# injectors and a custom program or Edit. These kits have been pretty good for belt slippage. Haven't seen this come up to much (mainly with the C5s). Upgrading the servos, shift kit and new clutch packs is a very good idea.
Tom
Order line - 1-877-4-TBYRNE
E-mail - tbyrne@tbyrne.com
SUPERCHARGER DISCOUNTS AVAILABLE!
Old Jan 30, 2004 | 12:26 PM
onyx's Avatar
well then, there you have it.
moregrip
Jul 26, 2016 11:21 AM
RustyD
May 23, 2016 07:04 PM
slimchevy2
Oct 4, 2015 08:02 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Silver8ado
Sep 30, 2015 11:42 AM
