Supercharger detonation Please Help
Old Jun 8, 2004 | 07:41 AM
  #21
OBXMarine's Avatar
I'd definatley look into a complete cold air kit. I was driving mine last night without the metal shroud for the K&N FIPK and my IAT's were 110 or so. That's with outside temps of 80-85. With the shroud in before, my IAT's were close to ambient temp. That hot air from the engine compartment will defiantley be an issue when running a blower.
Old Jun 8, 2004 | 08:29 AM
  #22
greentahoe's Avatar
Originally Posted by Allgonoshow
Any well equipped garage should have a Otc or snap-on handheld scanner
that could monitor, but not change, what's going on with the truck, a test drive
with the scanner would give you lots of info on iat, timing, kr , temps etc.
it wouldn't fix anything but would let you know what's up and what you need to fix.
they would charge for the time and it's a matter of finding someone with the interest to do it. would be a place to start.
David
I'll try that. The only prob is that all the performance shops around here are Ford shops. There has to be an Fbody shop near here.
Old Jun 8, 2004 | 08:39 AM
  #23
Allgonoshow's Avatar
Default data
you don't even need to go to speed shop, any well equipped garage could
look at the stuff.
David
Old Jun 8, 2004 | 09:09 AM
  #24
greentahoe's Avatar
look at the stuff.
David
A dealer would have a scanner right?!!
Old Jun 8, 2004 | 11:09 AM
  #25
Flyer's Avatar
Something else I didn't see mentioned was running a 160* t-stat. That might help get those under hood temps a little lower. Does the ortech system have an intercooler? From the sounds of it, it didn't. If not, that might be a little much timing.
Old Jun 8, 2004 | 12:37 PM
  #26
Default scanner
Yep
David
Old Jun 8, 2004 | 01:09 PM
  #27
greentahoe's Avatar
Ive got a 180 stat right now. Should I switch to a 160?? Im going to have a local guy tune the truck, but at $500 a shot I wanted to wait to get the Alky, headers, and smaller pulley. I just put the stock airbox on and will be doing a scoop tomorrow. Its just so hot!!
Old Jun 8, 2004 | 08:09 PM
  #28
greentahoe's Avatar
Also would a 34' radiator help with things??? I need to speak with Lyndon tomorrow and see how much fuel he has it set at. Im running 43 lb injectors so I know Ive got enough flow available. Im thinking that it would be better to richen it up a bit to be safe. Until then Im not going to put it in boost. I dont want any cracked pistons. Any other opinions/ ideas are appreciated.
moregrip
Jul 26, 2016 11:21 AM
5speedsilverado
Sep 25, 2015 06:50 PM
bagged7104SS
Sep 24, 2015 08:42 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
