Super charger
Old Apr 11, 2008 | 11:59 PM
06chevy5.3's Avatar
Default Super charger
Im buying a super charger and some 8.1 marine injectors come with it will these injectors fit in my truck its flexfuel and will they be enough?
Old Apr 12, 2008 | 01:18 AM
05GMCL33's Avatar
What supercharger kit are you getting? 8.1 marine injectors should plug right in.
Old Apr 12, 2008 | 01:57 AM
not if its flex fuel the connectors are different .but all you will have to do is find someone that sales the adaptors .
Old Apr 12, 2008 | 02:06 AM
06chevy5.3's Avatar
kenne bell
Old Apr 13, 2008 | 10:48 AM
06chevy5.3's Avatar
ok so I will have to get adapters, anyone know it they will flow enough with the super charger and cam.
Old Apr 13, 2008 | 01:14 PM
nonecktribe's Avatar
i think the flexfuel injectors are 42lbs...might not need the 8.1 injectors
Old Apr 13, 2008 | 01:16 PM
silveradokidd_4518's Avatar
8.1 marines will be plenty enough
Old Apr 13, 2008 | 01:27 PM
supercharged tahoe ss's Avatar
i have flex fuel if you are running 5 to 6 psi stock injectors will be ok tune truck and check duty cycle with stock injectors.
Old Apr 15, 2008 | 12:22 AM
06chevy5.3's Avatar
Il try it, im gona have the same kenne bell as you so il take ur word for it. Are you running 5 to 6 with the stock pully? What do you guys think of the cam i have with the sc its a 220/224 530/534 112lsa with the 1.75 rockers the lift is in the 540s how do you figure the overlap?
Old Apr 15, 2008 | 07:07 AM
Doobie's Avatar
I'm running 6.6 lbs boost on my Radix and using my flex fuel injectors and stock fuel pump with no problem. Magnuson sells their flex fuel kit without injectors or fuel pump as they are both higher capacity for flex fuel application. I believe the FF injectors are 38 lb. rated. Magnuson customer service is first rate and you could call and ask them how much boost a FF engine (injectors and fuel pump) will handle. Also FF engines run at lower fuel press. than stock engines. 48~54 lbs with key turned on with a drop of 4~10 PSI at idle is acceptable according to my GM service manual. They list 55~62 PSI for a stock engine fuel system with key in ignition and turned on. For comparison, My truck is 50 psi with key turned on and 48 psi at idle.
00loudchevy
Dec 3, 2015 05:54 PM
gaps
Oct 15, 2015 02:53 PM
1slwgto
Oct 1, 2015 01:51 PM
OHsixLS3
Sep 25, 2015 11:20 AM
Lthompson
Sep 15, 2015 07:55 PM
