sucked nitrous nozzle into the engine need help asap
hey guys well i had a great time with my truck until i sucked in a washer and a nitrous nozzle that was for my alky/water injection so do you think it could of made it into the cylinder? Also if it is really bad i need a motor does anyone know where i can get one? Looking for an ls1 or 6.0 so any help is greatly appreciated
ok i'm throwing these codes
P0706 Transaxle Range Switch Performance
P0300 Misfire Detected
I dont know what the hell the first one means
tia
marc
tia
marc
yeah i have no idea what that means... but man, that sucks man. this week will go down in history as the worst week ever for our trucks, i know this much <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
D"OH <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
pull the intake off and hope it didn't go into a cyclender <img border="0" alt="[cry]" title="" src="graemlins/gr_cry.gif" /> <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
<img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" /> <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
ok guys i got the tb off and i found the nozzle and a bunch of metal shards but i can't find the washer i'm working on taking the intake off but i'm 300 miles from my shop and all i have is like an adjustable box end wrenchd and a screwdriver and some other things i really need to start carrying tools in the truck
marc
marc
ok guys i need help getting the intake manifold off i have all the bolt on the side and the harness to the injectors but what is next i have to get this thing back on soon.
marc
marc
ok it went into the cylinder i took out the spark plug and it was all messed up the prongs were all bent up so we are going to see if there is anything in the cylinder and then if not we will reasemable and try to get the truck running and go from there.
marc
i'll get pics up of the sparkplug later
marc
marc
marc
Sounds like you are in the markwt for a new motor. Well, you could hone the cylinders of the 5.3, replace that piston if it needs it, surface the head, and maybe a valve job. If you have to pull the 5.3, I'd just swap in a LS1 or 6L.
It may drive home OK. I'd check to see if anything is still in the cylinder.
Luckily, the intake has that big semi-closed off interior area. Kind of like a tube with the top opened. I guess thats where you found your nozzle?
Sorry to hear your problems.
