Submersible fuel line for fuel pump
Old Mar 27, 2012 | 02:25 PM
Ferocity02's Avatar
Just ordered Gates 27093, 1' length 5/16 ID submersible fuel injection line, from my local O'Reillys for $26. I prefer not to risk it. It's only a 2-hour job to swap the line.
I'll do an experiment and soak my spare H357 hose in gas and see what happens.
Old Mar 27, 2012 | 02:26 PM
Atomic's Avatar
I have a gauge for that
it will swell and pop off the pump eventually
Old Mar 27, 2012 | 02:41 PM
Ferocity02's Avatar
It's clamped on both ends, but I see what you're saying. It will fail eventually when I'm in the middle of nowhere when it's 110F outside.
Old Mar 27, 2012 | 02:42 PM
smokeshow's Avatar
Mod with training wheels
That stuff on jegs is what I run. And yeah, if its not rated for submersion it will swell up and either burst or blow off of a connector. That dayco **** did it like 3 separate times. Went -6 braided after that..
Old Mar 27, 2012 | 04:44 PM
TIM Z's Avatar
11 sec. Truck Mod
Call Lonnie at lonnies performance and get some stock plastic corrugated line with the special Otiker (sp.?) clamps that the factory uses as they dont pinch the line causing a leak.
This stuff lasts for years and isnt expensive. Just my advice bud.
Old Mar 27, 2012 | 05:27 PM
Dezert1500's Avatar
I've got 27093 - 5/16"x1' Gates for $23 shipped. Also have 27097 - 3/8"x1' Gates for $25 shipped. If anyone needs some contact me.
Old Mar 28, 2012 | 10:14 AM
Bama2door's Avatar
I used generic fuel line in a pinch on my Aeromotive pump install with clamps and it swole up and popped off in about 3 days. I ordered and installed the Gates 27093 and so far so good.
Old Mar 28, 2012 | 07:41 PM
Ferocity02's Avatar
I swapped the line today, and good thing I did!!!
The hose actually wasn't in bad shape. It did swell slightly and feels a little mushier. But here's the part that got me. The side of the hose says
"FUEL VAPOR >PCV/EEC< 5/16 INCH (8.0mm) SAE 30R7 NOT FOR FUEL INJECTION SYSTEMS MADE IN U.S.A. BY GATES"
No wonder it was so cheap, those dumbasses gave me the wrong hose. I'm very glad I swapped it out. The Gates 27093 fit perfectly. Took about 1.5 hours to change.
Old Mar 28, 2012 | 08:51 PM
01silvy's Avatar
Good thing you swapped it when you did.. you can never trust parts people either, most of them just know how to sell the part.....
Old Mar 28, 2012 | 09:20 PM
Atomic's Avatar
I tell people, if its not $20 a foot and made by gates you got the wrong stuff.
