Stupid question of the day, Plug Wires?
Old Sep 22, 2007 | 11:49 AM
SlvrSierra4.8's Avatar
Default Stupid question of the day, Plug Wires?
When replacing plug wires does the metal insulator that sheilds the outside of the boot/spark plug come off with the spark plug wire or can it stay installed and the new wires just slid back inside the metal shield? Are the plug wires supposed to be an extremely tight fit on the plug itself when installed, seems like the factory wires are really snug and kind of a bitch to pull off? Maybe I just need to hit the gym? Any help is appreciated, Thanks-
Old Sep 22, 2007 | 11:54 AM
parish8's Avatar
single digit dreamer
i use the metal part to pull on when taking them off. stock wires that have been on awhile are kinda hard to take off.
Old Sep 22, 2007 | 01:02 PM
Thanks for the info, will give that a try, so the metal sleeves just slide on the new plug wires?
Old Sep 22, 2007 | 01:33 PM
parish8's Avatar
if your using stock wires then yes. if your going with some msd's then i discard the metal sleves. either way you want to feel a "click" when you put the new wires on. sometimes if i am not sure i am geting the click i put a little squirt of windex inside the boot. lets the wire slip right on and you can feel the click.
Old Sep 22, 2007 | 07:56 PM
Got them swapped out w/ out issues, Appreciate the help Parish
shupe
Aug 5, 2015 06:45 PM
USMCvet0311
Aug 1, 2015 07:45 AM
sauldgold
Jul 23, 2015 02:15 PM
bsgiffor
Jul 19, 2015 11:14 AM
