Stupid Fan question
Old Oct 15, 2010 | 06:29 PM
stone150's Avatar
Default Stupid Fan question
I know this topic has been covered but couldn't find all the answers.
I have a set of LS1 fans and a harness for them just sitting around uninstalled.
I saw a the 05+ setup in a truck today and it looks so much nicer then what I am looking at doing. So my questions are:
1. All i need is the 05+ fans and radiator
2. P/N for both?
3. will my ls1 fan harness work?
4. do I need any additional supports or anything?
5. will all hoses match up?
Old Oct 15, 2010 | 06:38 PM
budhayes3's Avatar
PT's Slowest Truck
All you need are the fans, radiator, harness and pcm tuning to turn them on. Your LS1 harness will work, but the connectors will be different, so you'll need to splice those in. No additional supports, but you'll need two bolts like the ones that are holding your current radiator in to bolt the fans in (can't remember what size bolts, and don't have part numbers, sorry.) Hoses all line up
Old Oct 15, 2010 | 06:39 PM
fastnblu's Avatar
2. P/N for both?
1)Y
2)Why, not getting thru a yard? it'd be cheaper than a dealer, plus they'll be fine.
3)IDK, maybe, maybe not; some others may chime in.
4)No. They use the holes that are in existing core support. My bolts that support wider rad & are needed, I got from yard.
5)Y
I see BH3 beat me to it. For once, he'll be able to beat me.
Old Oct 15, 2010 | 06:47 PM
double047's Avatar
14 Second Truck Club
That's some good info from you guys!
Old Oct 15, 2010 | 07:12 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by fastnblu
1)Y
Bolt your huffer on before you try and beat me Sally
Old Oct 15, 2010 | 07:40 PM
Coban's Avatar
Man, I just sold my stuff from my old 2004. I coulda hooked you up.
It looks so much better with the 05+ efans.
Old Oct 15, 2010 | 08:01 PM
budhayes3's Avatar
PT's Slowest Truck
Yes, I agree
BTW, you can get a brand new 34" radiator from radiatorbarn.com for about $160...(it was over $250 back when I got mine, but the 34" rads weren't as common then )
Old Oct 16, 2010 | 08:33 PM
stone150's Avatar
danmit
Old Oct 16, 2010 | 08:34 PM
stone150's Avatar
thanks guys, I did a quick search and couldn't find any in my area, but will continue to look
Old Oct 17, 2010 | 01:11 AM
budhayes3's Avatar
PT's Slowest Truck
Hey stone, just found a set in our classifieds for $150...
https://www.performancetrucks.net/fo...d.php?t=470850
