Stupid crate engine question
Old Apr 5, 2017 | 12:42 PM
someotherguy's Avatar
Default Stupid crate engine question
OK, I know this site is more oriented towards hardcore mods and not crate engines. But I think it's also probably the best place to ask this question which may seem stupid, but maybe I'm just missing something?
LS7 pn 19244098 - 505HP/470TQ 11:1 - $13600
LS376 pn 19301360 - 525HP/486TQ 10.7:1 - $8230
I know that's been the LS7 price pretty much since its introduction years ago as a crate. But damn...that's a nearly $5400 premium for less power out of more cubes. Both examples are dressed long blocks. What am I overlooking here?
Richard
Old Apr 5, 2017 | 01:04 PM
madmann26's Avatar
Richard
7.0L vs 6.2L.
I don't believe they are the same block either.
Old Apr 5, 2017 | 02:14 PM
Right, but the cheaper engine is more powerful, out of less cubes, for a lot less money.
Richard
Old Apr 5, 2017 | 02:35 PM
Atomic's Avatar
I have a gauge for that
The LS7 is lighter and built more for NA whereas the LS376 is an iron block meant more for power adders.
Old Apr 5, 2017 | 02:45 PM
Straight from GMPP's site on the part # for the LS376 I posted: Block (P/N 12623967): Cast aluminum with 6-bolt, cross-bolted main caps
Richard
Old Apr 5, 2017 | 02:56 PM
Atomic's Avatar
Ah, I thought you meant LSX376.
Well the most obvious difference are the cylinder head styles, camshaft, and max rpm rating. The LS376 is basically an LS3, and the LS7 is a high rpm NA engine. For $5k I would go with the LS3 and a blower.
Old Apr 5, 2017 | 03:04 PM
Yeah, clearly there are better bang-for-the-buck combinations, and that's kind of what I was noticing in the LS7 vs. LS376, a $5400 difference in price and on the cheaper end you get more HP/TQ. Both are aluminum block so weight difference would have to be minimal.
Richard
Old Apr 5, 2017 | 03:40 PM
Atomic's Avatar
As far as engines go though, the LS7 is better. The power difference is almost certainly because the LS3 has a much larger cam. The LS7 heads are also better, and the rotating assembly is lighter so it is more responsive.
Old Apr 5, 2017 | 04:56 PM
Jermoslin's Avatar
that much dough you can get a LSX454
Old Apr 5, 2017 | 06:35 PM
TXsilverado's Avatar
slap a turbo on a 6.0 with forged pistons and rods and make more power than both engines for less money.
